Author Topic: LED Interior Lighting  (Read 14658 times)
Offline robertglines1
  • steam nut
Re: LED Interior Lighting
« Reply #15 on: May 05, 2012, 07:33:52 PM »
Michael;any base with g-4 or m 16  will except the led. or you can solder direct to the led studs and make your own fixtures or modify some existing ones.
Offline dukegrad98
« Reply #16 on: May 05, 2012, 08:30:14 PM »
I have in new build. Works great. 64 ft in front salon. Usa shipper  same price!! China shipper one order 3 months and I refused them and filed claim thru E-bay and got refund.  Using on dimmer and they work great.  Bob
Bob, what is the seller's ebay name?  I need a couple rolls and don't want to deal with shipping from China.  Thanks!!
Cheers, John
  • steam nut
« Reply #17 on: May 05, 2012, 09:41:51 PM »
I think they were from Arizona. I'll see if I can find label tomorrow. I used the 300 per roll. If you want allot of light go for more.  $12.50 roll
Offline belfert
« Reply #18 on: May 06, 2012, 01:44:12 AM »
I did a search on Ebay and found 200+ listings for "led strip lights USA".  There are 30,000+ listings if the USA portion is dropped.
Offline Eric
  • Currently in Northeast Ohio
« Reply #19 on: May 06, 2012, 06:14:12 AM »
There is a button on the left where all the filters are... You can pick sellers: all,us/Canada
Offline Hi yo silver
« Reply #20 on: May 06, 2012, 06:30:20 AM »
I'm following this with interest because I'm trying to find a fixture I can hang inside an existing lampshade, running the powercord to the back of an end table, then down into a drawer to a rechargable battery. That way, I can remove the battery occassionally for recharging and have a lamp where there is no receptacle.
Dennis
  • steam nut
« Reply #21 on: May 06, 2012, 06:49:18 AM »
Dennis you can buy the G-4 receptacle for about $3 to fit the individual led Like DKO bought (12 Volt) can use M-16 receptacle also just need to bend prongs a little.     Local lamp Shop should have receptacle.  Bob
Offline chev49
« Reply #22 on: May 06, 2012, 07:41:04 AM »
you can also buy the led light bulbs from china = the mr16 base ones - that you get a remote with to turn it on, and change to whatever color you want, and do other color sequences...
i bought 2 just to see what they were, cost around 9 bucks each shipped...
now my wife says i have a disco bus... ;D
« Reply #23 on: May 06, 2012, 03:06:47 PM »
I can't put no disco lights in my bus; Marilyn will want me to install a pole...
Thanks for the help guys. I'll know what to look for.
Dennis
Offline belfert
« Reply #24 on: April 06, 2013, 03:15:40 PM »
Bob, how did you cover the LED strip lights so they don't look like you attached a long narrow circuit board to your ceiling?
Offline lvmci
  • lvmci
« Reply #25 on: April 06, 2013, 04:05:14 PM »
I just bought a nice looking bronzed fixture at HD on sale for $13, that had a new style bulb called a GU10 base with a MR16 body, got a LED 12V from phillips, expensive at $30 but 60,000 hrs and 3 watts, no heat, to replace the halogen, saves wattage, saves heat, and now hanging down, bulb and lampshade are secure with this 1/4 turn twist lock bulb, lvmci...
MCI 102C3 8V92, Allison HT740
Offline Jnbroadbent
« Reply #26 on: April 06, 2013, 10:32:33 PM »
I've been thinking about a small, cheap, LED solution and this is it! Thanks guys
Jon
1980 Mc9 w/ veg oil
8v71
Jacksonville Fl
Offline ridgeroadrunner
  • Jeff
« Reply #27 on: April 07, 2013, 08:23:33 AM »
i read on the forum about LED Super Lights, we changed the lighting  in our coach to LED Strip Lights works great looks great and they are great people to deal with. Shipping is high so order enough to make it worth the shipping . The shipping cost the same as one light .We orderd ours from LED Super Brights of St.louis.
1980 MCI 5
