Author Topic: Plate on DD 6V92  (Read 971 times)
Offline Tikvah
    • Dave & Amy
Plate on DD 6V92
« on: June 23, 2012, 08:49:04 AM »
I have the rear bumper and the plate off behind the engine, working on a hitch.
The engine is very clean, was new or newly rebuilt when I purchased the bus.  But, I just found this plate.  I don't know what it means, but I assume some kind of details about the rebuild.
Can anyone give some input?
The information reads (as best as I can tell):
  T R A N S O O   (or T R A N S C O)
  00       295
  Bore  -  STD
  ROD  -  010
  MAIN  -  010
Thanks for any input,
Dave
1989 MCI-102 A3
DD 6V92 Turbo, Alison
Tons of stuff to learn!
http://dave-amy.com/
Offline chev49
Re: Plate on DD 6V92
« Reply #1 on: June 23, 2012, 10:22:16 AM »
engine bore and crank spec's.. nice that it is posted instead of finding out the hard way.
Offline Tenor
    • Three Men and a Tenor
« Reply #2 on: June 23, 2012, 10:29:12 AM »
Bore  -  STD  Means that the size of the piston sleeves (cylinders) is STandarD
  ROD  -  010  The crankshaft has been turned down in diameter .010 inches for new bearings between the crankshaft and the connecting RODs.
  MAIN  -  010  The crankshaft has been turned down in diameter .010 inches for new bearings between the crankshaft and the engine block.  These bearings are called the MAIN bearings.
Nice to have that documented!!!
Glenn
Glenn Williams
Lansing, MI
www.threemenandatenor.com
8v71
4 speed Spicer
  • Gold Donor
« Reply #3 on: June 23, 2012, 10:34:59 AM »
It is a rebuild from Transco Feb of 1995 the crank has been turned on mains and rods which is not bad 92 series will pretty much always be standard bore too much money and time to bore a 92 series not like boring a 71 series
Offline lostagain
  • MC5C
« Reply #4 on: June 23, 2012, 12:01:02 PM »
Don't take that info for granted. When I overhauled my 4-71, I ordered parts according to a plate like that on the block. They were the wrong size and had to reorder. The plate was from a previous rebuild and nobody bothered to remove it.
JC
JC
Blackie AB
1977 MC5C, 6V92/HT740
