Author Topic: 8V71 Starter LH  (Read 4018 times)
Offline 06 Bill
  • Jr. Member
8V71 Starter LH
« on: November 08, 2006, 06:01:51 AM »
Is the starter on a 8V71 12v Left rotation & 12v Right rotation wound in the same direction.
The part #s for a V drive & a T drive seem to be the same as far as the armatures go.
The splines are straight not spiraled as on a dedicated rotation armature.
Thanks in adv 06 Bill
Offline busguy01
Re: 8V71 Starter LH
« Reply #1 on: November 08, 2006, 09:17:45 AM »
On auto type starters you can change rotation by clocking the brush holder to a different slot on the case.  I am fairly  sure that the same holds true on any DC starter or motor. You are changeing the relation of the brushes vs the field.
JimH
Started with nothing - still have most of it left!
1963 Eagle 01 with Detroit 60 series done (Gone-sold!)
MCI EL3 in progress. raised roof & Slides
2009 Revolution 42 Sticks and staple
Summer - Yankton, South Dakota
Winter- Sebastian, Florida
Offline RTS/Daytona
  • Pete RTS/Daytona ->'89 TMC 35' 102" 6V92TA 4:10
    • BUS CONVERSION PARTS FOR SALE / PROJECTS
Re: 8V71 Starter LH
« Reply #2 on: November 08, 2006, 02:22:43 PM »
But remember - the clutch on the starter gear has to ratchets in the opposite direction
