June 23, 2018, 06:39:38 AM
Author Topic: What adhesive to use for Soundown composite foam?  (Read 1281 times)
Offline belfert
« on: August 18, 2012, 06:31:23 PM »
My generator enclosure had some composite foam adhered to the inside top of the enclosure.  It came loose and partially melted on the exhaust.  I purchased some Soundown composite foam to replace it.  What is the best adhesive to adhere this to the inside top of the enclosure?
Offline jjrbus
  • MCI5C/N Ft Myers FL
Re: What adhesive to use for Soundown composite foam?
« Reply #1 on: August 18, 2012, 08:50:33 PM »
Mine was glued and  also held in place with large ??? washers??? for lack of a better word.  JIm
Offline belfert
« Reply #2 on: August 18, 2012, 09:21:56 PM »
Probably mechanical fasteners.  The fasteners are attached to the metal with glue of some sort.  I suppose I could use those by grinding off the paint to epoxy the fasteners on.
I'm still wondering what type of adhesive to use.  Some spray adhesives would attack the foam.
