June 23, 2018, 08:32:10 PM
Author Topic: Window molding for1980 H8H649  (Read 2880 times)
Offline tanman496
« on: September 18, 2012, 02:40:41 PM »
Hello all I have a 1980 H8H649 I have been told its the same as a 4905a what i am looking for is the channel molding and weather strip for the sliding window on the drivers side. Does anyone have any advise
Mark
Offline RJ
Re: Window molding for1980 H8H649
« Reply #1 on: September 18, 2012, 07:15:53 PM »
Name???
Call Luke @ US Coach in NJ. 1-888-262-2434 between 9-5.
PS:  Help us help you.  Edit your profile (click on the tab in the menu bar above) to include a signature line with at least your first name, home base city/state and coach make/model.  No sense sending you to NJ for help if you're in AZ, right?
RJ Long
PD4106-2784 No More
S13406 1978 MC-5C Converted
6V71/MT-644
S14947 1980 MC-5C Shell
6V92/HT-740
Cheney WA
Offline tanman496
« Reply #2 on: September 19, 2012, 09:05:28 PM »
Thanks for your help. I tried to post a photo and update my profile but cant seem to get my photo up. lol
Mark
Offline Red Rider
  • God put me here to accomplish certain things--- I'm so far behind I'll never die.
« Reply #3 on: September 20, 2012, 05:56:45 PM »
I got all my slider moulding--- both the surround and sliding felt for my 4106 from Luke. I got my "D" window moulding from Peninsula Glass.
Hope this helps
Mike AKA; Red Rider 4106-1885
Offline tanman496
« Reply #4 on: September 20, 2012, 09:14:16 PM »
Thanks alot I called Luke and looks like we will be putting a order in .
Mark
Offline rcbeam
« Reply #5 on: September 23, 2012, 03:36:44 PM »
Mark:  What is the serial number of your bus?  My first bus was a 1980 h8h also... number 175.  If I remember correctly there were only 225 made that final year.  Mine had lots of problems and I ended up having to see it (give it away) to a guy that wanted it only for parts.
Russell
MC8
Lexington Ky
Russell
1976 MC8
Lexington KY
www.sweeteveningbreeze.blogspot.com
Offline tanman496
« Reply #6 on: September 23, 2012, 04:39:56 PM »
My number is 009 of 225
Mark
Offline RJ
« Reply #7 on: September 24, 2012, 10:36:35 PM »
Mark -
FYI, H8H649-009 was delivered new as fleet number H-802 in March of 1979 to Wurtsboro-Hudson Corp (dba Hudson Transit Lines), HQ'd in Mahwah, NJ.
RJ Long
PD4106-2784 No More
6V71/MT-644
6V92/HT-740
Cheney WA
Offline tuccitown
  • Jr. Member
« Reply #8 on: September 25, 2012, 12:11:43 AM »
Mark,
Interesting mine is 1979 H8H649 053, yours is a 1980? Did 009 come with a manual or automatic transmission?
Jack
1979 GMC H8H649-053 Conversion in progress.
1955 GM PD 4501-377 Converted.
Offline tanman496
« Reply #9 on: September 25, 2012, 08:53:25 AM »
Mine came with a manual trans but someone installed a VS2-8 automatic but it seems to have so parts missing cause you have to shut the bus off to change from foward to reverse and thats a pain in the @$#.
Mark
Offline tuccitown
  • Jr. Member
« Reply #10 on: September 25, 2012, 10:58:55 AM »
I hear ya, my clutch was out of adjustment/ hard to get in gear from neutral. I had to shut down to get it in gear from neutral. Guess I had nothing to complain about at least I could get from forward to reverse without shutting down.
I was told that the H8H models came with autos so have been curious to know if mine was standard from the factory or not. There is a cutout in the bulkhead to allow the transmission pan to clear that doesn't look stock, however it's hard to believe someone one go through the trouble to outfit it with the necessary linkage and clutch to convert to standard transmission.
Sorry to hijack your tread hope your molding works out.
Jack
Offline RJ
« Reply #11 on: September 26, 2012, 01:05:34 AM »
Jack -
According to the information included with my GM coach delivery roster is a list of 4905s that came from the factory with automatics.
93 out of 225 H8Hs came with autos, the rest were manual gearboxes.
RJ Long
PD4106-2784 No More
6V71/MT-644
6V92/HT-740
Cheney WA
Offline tuccitown
  • Jr. Member
« Reply #12 on: September 26, 2012, 01:45:45 AM »
Thanks RJ,
That makes more sense.
Jack
Offline tanman496
« Reply #13 on: September 26, 2012, 11:29:01 AM »
thanks everyone for your help the molding I got from Luke at US Coach woked out well.  thanks again Mark
Mark
