Author Topic: Looking for Mini-Splits  (Read 18876 times)
Offline Tikvah
    • Dave & Amy
« on: October 27, 2012, 04:27:25 AM »
Funny time of year to be looking, but that is where I am in the conversion process.
I'm looking for two mini-splits.  One about 9000 and the other 12,000  (one in the bedroom, and the other above the windshield).
Ideally, with a heat and cool heat-pumps, and I like the inverter technology.   (Do "Heat Pump" units always have heat?)
Also, they need to be 110-115 voltage.  I only have an RV generator for now.
Trying to stay on a tight budget.  Anyone know where I can get a good deal?
Dave
1989 MCI-102 A3
DD 6V92 Turbo, Alison
Tons of stuff to learn!
http://dave-amy.com/
Offline robertglines1
  • steam nut
  • Platinum Donor
Re: Looking for Mini-Splits
« Reply #1 on: October 27, 2012, 07:33:44 AM »
one stop mini-split shop    is one. I used Soleus inverter Type   But shop around for deals and call for free shipping on two or free line sets.  good time of year to deal.   Ebay is good source just compare apples top apples  410 refrigerant is a must to get high performance with low amp use.  Just my experience  fasten all lines secure and you should be good to go. Mine are not road tested. My friends are for over 5 years and doing fine.   Bob
Offline Tikvah
    • Dave & Amy
« Reply #2 on: October 27, 2012, 08:28:02 AM »
Just doing a comparison on the 9000 unit.  Solace Brand.
The Heat Pump is 800W and 7.3A for $439
The Inverter is 730W and 6.5A  for $725
That seems like a small power difference for a big price difference.  Tell me why I want the Inverter.
Also, the 12,000 unit is not available in the 115V with the Inverter... ???
Dave
1989 MCI-102 A3
Offline Melbo
  • MC8 under construction
« Reply #3 on: October 27, 2012, 08:34:00 AM »
No hard starts and power spikes with the inverter
HTH
Melbo
Offline Tikvah
    • Dave & Amy
« Reply #4 on: October 27, 2012, 03:11:33 PM »
Here is a "Premium" mini-split
http://www.highseer.com/19-seer-inverter-mini-split-ductless/ductless-mini-split-heat-pump-wyb012am9.html
I'm shy of the name Pioneer.
But it is 12,000 with 115V.... says it is "Variable Speed"    hmmmm
Dave
1989 MCI-102 A3
Offline Melbo
« Reply #5 on: October 27, 2012, 03:42:28 PM »
The inverter changes the AC current to DC current so instead of hard starts and only one speed the compressor runs on DC and just ramps up the speed as necessary to supply the cooling or heating called for from the remote unit.
Just the way it was explained to me.
HTH
Melbo
Offline jjrbus
  • MCI5C/N Ft Myers FL
« Reply #6 on: October 28, 2012, 04:25:59 AM »
I am toying with the idea of adding a mini to the main part of my house.   The concern I have is finding parts and service, a minor problem could be the end of an unsupported unit.
I have no doubts about using a mini they are used every where in Asia.
 Buying a name brand would use up any savings, but buying two chepo's and keeping one for a replacement or parts might be an option?
   Just thinking in print.                                                  JIm
Offline sledhead
« Reply #7 on: October 28, 2012, 05:59:56 AM »
As my heating buddy put it. There are all the same crap inside so save your money and buy a unit that you can get locally at a good price and when it craps out in 4-5 years the new replacement one will be even cheaper then the first.Thanks china for all the low prices . just add a soft start capacitor ( about 20 bucks )         dave
dave , karen
  • steam nut
  • Platinum Donor
« Reply #8 on: October 28, 2012, 06:44:48 AM »
In Evansville Ind for the same model # from over internet. The wholesale supplier wants twice the money..I believe in buy local! But at twice the $ takes the zing out of it.   Bob I have a 24000 Inverter style  Klimaire in home now. 2600sq ft plus basement Midwest over 100 for several weeks.  My elect bill is 55% of what it was last year over same 5 month period and replaced a 5ton and a 3 ton heat pump.  At 108 degree it got to 78 in our home. I am thinking of adding another 12000 next year.(maybe)  The reason I used in home is because of how well they worked in coach. Again I'm on a long term build so have not been road tested.On the other side I have a friend that has been running his for over 5 years.(two)  I have three installed and very seldom run more that one sitting still except for initial cool down or warm up. range from single digets to 100F  Bob
« Reply #9 on: October 28, 2012, 07:20:30 AM »
I was at Sigler a Carrier distributor they had a mini split American made with the Copeland compressor wholesale price on the 12,000 btu was 2800 bucks twice the price of a China made unit
I have no idea if there is any truth in what I was told but the heavier in weight in a AC unit the better the unit,I did fall for it though and bought 3 six ton roof mounts for the restaurant the Carriers were about 30 lbs heavier than a Goodman the same size
« Last Edit: October 28, 2012, 07:36:32 AM by luvrbus »
Offline jjrbus
« Reply #10 on: October 28, 2012, 09:01:29 AM »
In my search one thing I thing that is brought up often is that a well installed cheap unit will outlast a poorly installed quality unit.  I read it on the internet so it must be true!
 Our resident expert claims that the mini's are not as effective  at removing humidity, like living in a cool sponge was the term used.  I never noticed that in the tropic's.
 How would a soft start capacitor be added?                                JIm
Offline Oonrahnjay
« Reply #11 on: October 28, 2012, 09:09:21 AM »
(snip)   How would a soft start capacitor be added?                                JIm
     Yeah, if "soft start" is the big thing for a $1700 unit versus a $900 version, I'd like to know that, too.
     BTW, super woodwork in your bus, JJ.  And is there info on your webpage about your leveling system?  Do you use the suspension airbags or separate air jacks?  And what air conditioner do you have installed now?
« Reply #12 on: October 28, 2012, 09:16:29 AM »
Just remove the capacitor and replace it with a soft start all they do is spike the voltage I replace 200 v capacitors with 300 v all the time that will start one take the laboring out of starting lol
Offline sledhead
« Reply #13 on: October 28, 2012, 11:53:42 AM »
On my unit in the bus the soft start kit (capacitor ) you add to the org. capacitor piggy back wires came in the kit can't remember the name .just ask were you buy the a/c . My a/c in the bus is a 9000 BTU cool 10,000 BTU heat comfort aire by heat controller inc jackson mi . Wholesale price $675. + tax.1/4 " and 3/8 " lines extra approx $100. bucks                               dave
dave , karen
Offline Tikvah
    • Dave & Amy
« Reply #14 on: October 28, 2012, 02:11:21 PM »
When you talk about soft-start capacitors, are you still talking about mini-splits?   I'm understanding that the Inverter type wouldn't need the soft-start....  they already are ???
How many of you are already using mini-split in your coach?
How many units and what size?
How did you set up the outside unit?
Pictures???
Dave
1989 MCI-102 A3
