Author Topic: Gasoline/carburetor gumming  (Read 9697 times)
Offline boogiethecat
    • HeartMagic
Re: Gasoline/carburetor gumming
« Reply #15 on: November 30, 2012, 09:19:57 AM »
Convert it to propane.  Problem solved, simple, cheap, most of all RELIABLE\I
It'll sit for years and start on the first cranking
1962 Crown
San Diego, Ca
Offline Iceni John
« Reply #16 on: November 30, 2012, 12:38:26 PM »
I plan on doing that.   Champion's website no longer lists any LPG generators  -  they used to have a few LPG models.   Do I need to replace the entire carburetor, or can I adapt my present carb?   Are there kits available to do this?   FYI, it's a 196cc Honda-clone engine.   Fortunately I have a spare outlet on my LPG manifold that can feed it.   If it's not a major job I'll convert it soon.
Thanks, John
2kW of tiltable solar.
Offline wg4t50
« Reply #17 on: November 30, 2012, 02:25:27 PM »
Yes, LP or Nat Gas is perfered for simple and easy operation.  Depends on the engine, some are very simple to adapt to the vapor fuel, some take a new mixer/carb setup.
Only down side to the LP fuel, is the cost, sure is nice, just expensive fuel, why I built a 12 kw diesel, burns 1/3 the gal of the LP dling the exact same load.
Do what makes you happy
Dave
MCI7 20+ Yrs
Foretravel w/ISM500
WG4T CW for ever.
Central Virginia
Offline opus
« Reply #18 on: November 30, 2012, 03:32:58 PM »
Aside from being more costly, you'll lose 25% power too.
Offline Iceni John
« Reply #19 on: November 30, 2012, 04:25:34 PM »
I'm not worried about the cost  -  my generator is only for very occasional emergency use, not my primary source of electricity.   If I lose some output power, again it won't matter much.   I just want to be sure that if/when I actually need it to run, it does.
Thanks, John
Offline Hi yo silver
« Reply #20 on: December 02, 2012, 10:13:57 PM »
I like "Sea-Foam" gas treatment. Like others mentioned above, just put the prescribed amount (I just approximate it, using about four ounces per five gallons of gas) before I fill the can. It's automatically well mixed when I fill the can. Then I pour from the five gallon can to smaller containers for mixing 2 cycle oil. I don't run them dry, just leave the gas in them until I use them next, sometimes three or four months at a time. I have about 14 different gas powered gadgets around here and the SeaFoam works well for me. The best price I've found is at Northern Tool. No carb problems in about seven years now. (Knock on wood)
So Far, So Good...
Dennis
    • HeartMagic
« Reply #21 on: December 03, 2012, 09:47:07 AM »
I use these guys.  You can do it 2 or 3 different ways.  I simply buy the garretson model KN regulator (it's highly recommended- others don't perform as well), take the carb off and drill a 1/4 inch hole up through the middle of the main jet into the venturi, solder a 1/2" brass hose barb to a piece of 1/4" brass tubing and cram it up into the hole just drilled so that it sticks about halfway into the venturi.  Then use a 1/2" ID hose to hook the hose-barb to the regulator's output, with a 1/4" gate valve in the middle.  The gate valve serves as a richness adjustment- it's somewhat tricky to adjust the first time but once you've got it running it's simple to tune and it's good forever without readjusting.
This method costs about a hundred bucks (mostly for the KN regulator) and takes me about half an hour.  You can occasionally find KN's much cheaper on ebay
If you want to do it simpler and less permanent, use a kit from these guys.
http://www.propanecarbs.com/tri_fuel_kits.html
1962 Crown
San Diego, Ca
Offline HB of CJ
Does The Gen Set Have Rubber Fuel Lines?
« Reply #22 on: December 03, 2012, 10:21:17 AM »
Is the fuel tank coated?  Maybe you have a incompatability (sp) with the type of fuel you are using.  The tank coating and rubber fuel lines (if any) are literally melting and clogging the carb?  FWIW, we always ran the gas out of the carb, be it airplanes, bikes, boats, tractors. etc.., particularily (another sp) if stored any time.  I can't speeeel today.  HB of CJ (old coot who needs his coffed) :) :) :)
Offline belfert
« Reply #23 on: December 03, 2012, 01:11:09 PM »
I've heard that the ethanol in E10 gasoline will dissolve certain types of fuel lines.  That probably explains why I had a fuel leak on my Stihl weed whip.
Offline Iceni John
« Reply #24 on: December 03, 2012, 07:32:22 PM »
Their website is helpful.   Maybe that's how I'll do it, with the conversion kit they sell for Champion's carbs.
Thanks, John
