BCM Community
Welcome,
Guest
. Please
login
or
register
Login with username and password
BCM Home
Forum
Help
Forum Rules
Search
Login
Register
Contact Us
BCM Community
Bus Discussion
(Moderator:
Lighting Help Please
« previous
next »
Print
Pages: [
1
2
All
Go Down
Author
Topic: Lighting Help Please (Read 6825 times)
ridgeroadrunner
Jeff
Newbie
on:
December 15, 2012, 08:11:43 PM »
where do you find 12 volt DC Fluorescent light fixtures for indirect lighting. One of my fixture's is broke and iam trying to find a replacement.
Logged
1980 MCI 5
Lin
Hero Member
1965 MC-5a
Re: Lighting Help Please
Reply #1 on:
December 15, 2012, 08:35:55 PM »
Not sure exactly what you are looking for, but have you tried Camping World or similar? Amazon and Ebay or also good places to search.
Logged
Hero Member
Reply #2 on:
December 16, 2012, 12:16:47 AM »
Solarseller.com has a full selection of DC fluorescent light fixtures at decent prices.
Logged
Len Silva
Hero Member
Angle Parked in a Parallel Universe
Reply #3 on:
December 16, 2012, 07:49:12 AM »
Find the part number on the ballast and Google that.
Logged
Hi yo silver
Hero Member
Reply #4 on:
December 16, 2012, 08:05:46 AM »
Wouldn't many older urban buses have them? Plenty of them being retired. Personally, I have had a problem finding a 110 volt dimmable ballast.
Dennis
Logged
Blue Ridge Mountains of VA Hi Yo Silver! MC9 Gone, not forgotten
pvcces
Hero Member
Reply #5 on:
December 16, 2012, 10:07:30 PM »
Check with Luke at US Coach. He can get you the ones for buses, and they will be better built than RV ones, I expect.
good luck.
Tom Caffrey
Logged
Tom Caffrey PD4106-2576
Suncatcher
Ketchikan, Alaska
goutoe
Full Member
Reply #6 on:
December 17, 2012, 07:31:59 AM »
Jeff my bus has the old florescent fixtures built in to the cabinets, two of the ballasts have gone bad Ive checked everyhere I can think of for replacements found none, so I am making the change to LED strip lighting, I have eveything bought to make the change, hope to complete it this winter, I have bought most of the strip lights on Ebay and found all kinds of flat mount lighting at Menards, it is all 12volt DC. very easy to wire.
John.
Logged
John & Linda 1977 AM General 6V92 turbo Detroit 3 Speed allison, 40 ft.
Hero Member
Reply #7 on:
December 17, 2012, 08:01:10 AM »
I saw a comparison in lumens per watt produced (I believe I saw the comparison online). Florescent lights and LED lights are so close that maybe the extra cost for LED's isn't worth it. I like the light that comes out of florescent lights. LED's have a more focused beam that requires multiple LED's or a lens. Good Luck, TomC
Logged
Oregonconversion
Sr. Member
Reply #8 on:
January 09, 2013, 12:43:47 AM »
I would just go with high output LEDs. Such better light quality. You can get the color spectrum that you like too. I like very cool lighting myself.
Logged
1977 MC8
8V92 HT740
Ed Hackenbruch
Hero Member
Reply #9 on:
January 09, 2013, 04:30:23 AM »
Last spring i replaced all but one of my florescent tubes with led tubes. Yanked out the ballast resistors and wired the new bulb in. One new tube replaced two old tubes, gives out more light, uses less juice, does cost more but should last a lot longer. Been very happy with them so far. Finally replaced the other one just a couple of days ago.
Logged
Used to own a 1968 MCI 5A with 8V71 and Allison MT644 transmission. Now have a 1977 MCI 5C.
Sam 4106
Hero Member
Reply #10 on:
January 09, 2013, 09:18:05 AM »
Ed, please share your source. I would like to change some of my 18" tubes as the ballasts fail. Hopefully the single LED won't be much more than a new ballast and two new tubes.
Thanks, Sam
Logged
Ed Hackenbruch
Hero Member
Reply #11 on:
January 09, 2013, 10:38:35 AM »
Sam, i got them from a vendor at an rv rally, i think they are called Bright Star or Star Bright or something like that. I just saw them at an RV Parts place the other day. When my lot neighbors get home from shopping i will look at the package for the name.....gave them about a dozen florescent bulbs since they still use them in their bus.
Logged
Ed Hackenbruch
Hero Member
Reply #12 on:
January 09, 2013, 11:33:04 AM »
Update, They are the Revolution T8-18 replacement bulb by Starlights Inc. 200% more efficient than a standard fluorescent tube, draws 623 milliamps, 810 lumens, 4500K, says 9-25v 7.1 w, although elsewhere it says that the pulse width modulator guarantees the same light output regardless of voltage fluctuations (11-16 volts). 60,000 hour life expectancy, lasts 12 times longer than a standard fluorescent bulb. Two wires to hook it up and you use the same end brackets. Has a ratcheting design that lets you point the light to the area that you want lit up most, has a light pattern up to 160 degrees.
Logged
Hero Member
Reply #13 on:
January 09, 2013, 03:33:33 PM »
The first place to start looking for anything is google!
Logged
akroyaleagle
Hero Member
Reply #14 on:
January 09, 2013, 05:52:21 PM »
Is this what you're looking for?
http://www.solar-electric.com/iotadcballasts.html
Logged
Joe Laird
'78 Eagle
Sioux Falls, South Dakota
Print
Pages: [
1
2
All
Go Up
« previous
next »
BCM Community
Bus Discussion
(Moderator:
