Author Topic: I.C.C confusion  (Read 3139 times)
Offline Darkspeed
I.C.C confusion
« on: December 27, 2012, 05:36:53 PM »
In my x-6114 gm coach maintenance manual there are two valves described.
1. Page 17 - "Two way control valve (Also I.C.C. Valve)" that limits pressure to the front brakes on slippery roads.
2. Page 19 - "Auxiliary brake control valve (I.C.C.)" that isolates the pedal and aux tank and fully loads the rear brakes
In reading a lot of posts people seem to call both of these valves the I.C.C. valve.
Am I correct in these being two different valves, maybe that look the same?
If so was one or both an option on some buses?
I have one unlabeled flip valve on the drivers side wall - i have not traced it out yet.
It's all math and metal...
Offline Sam 4106
Re: I.C.C confusion
« Reply #1 on: December 27, 2012, 05:52:11 PM »
On the 4106 that we had, the rear brakes were applied whenever the fast idle was engaged. I wonder if that is the function of the valve on page 19.
Good luck, Sam
Offline RJ
Re: I.C.C confusion
« Reply #2 on: December 27, 2012, 05:55:11 PM »
Todd -
The rarely ordered optional front brake limiting valve was sometimes mounted on the floor, right in front of the driver's seat.  Driver could flip it on/off with his heel.
The other ICC valve was originally mounted in the console to the driver's right, along with the PA mic and amplifier.  This valve was standard on all coaches.  Some drivers found out the hard way that it was NOT a parking brake, because if you shut down the coach and left it with this valve "on," as soon as the air pressure dropped, the bus would roll. . . (unless parked in gear or with the Johnson bar on.)
Both valves were a flip-style design.
It would be my guess that the one on the driver's wall has been relocated from the driver's console, if that has been removed.
Sam -
Wasn't your coach set up such that the fast idle wouldn't come on unless the parking brake was set?  Your MCI is probably set up that way also?
« Last Edit: December 27, 2012, 05:57:43 PM by RJ »
RJ Long
PD4106-2784 No More
Cheney WA
Offline Darkspeed
Re: I.C.C confusion
« Reply #3 on: December 27, 2012, 07:02:48 PM »
Thanks RJ! Thats what i needed to know.
Im guessing it got relocated.
Offline Sam 4106
Re: I.C.C confusion
« Reply #4 on: December 28, 2012, 08:13:53 AM »
RJ, you are probably right in both cases. It has been over 3 1/2 years since we sold our 4106 and the memory fades with time. I have never tried engaging the fast idle on our MC 8 without the parking brake set. But, with the DDEC II, I am not sure the PO wired the interlock into the fast idle. Some day I will check that if I remember that long.
Thanks for the info, Sam
Offline Lin
  • 1965 MC-5a
Re: I.C.C confusion
« Reply #5 on: December 29, 2012, 04:32:52 PM »
The Jakes ate our fast idle, but when we had it, it would only work with the parking brake engaged.  I believe that was standard setup.
