Author Topic: Starter Button Stopped Working  (Read 4627 times)
Offline Paso One
Re: Starter Button Stopped Working
« Reply #15 on: January 16, 2013, 01:59:29 PM »
Another idea is installing a push button neutral safety switch.
I installed one so I could start the old VH 9 in gear, this allowed the transmission to warm up faster on our - 40 mornings.
Actually one of the factory upgrades for the VH-9 caused engagement grinding unless transmission was warm.
Worked well I might leave it wired up as it is just a jumper between two terminals in the front panel.  short piece of wire and a spring loaded button.
Your just pushing two buttons to start.  Theft device also :)
68 5303 Fishbowl 40'x102" 6V92 V730 PS, Air shift  4:10 rear axle.
1973 MCI 5 B 8V71 4 speed manual
1996 MCI 102 D3 3129 Cat engine 7 speed manual  and yes I would.
Offline gus
« Reply #16 on: January 16, 2013, 02:08:25 PM »
The old semi I used to drive had two start buttons (Cadillac) and had to be held down until the oil pressure came up.
