BCM Community
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
BCM Home
Forum
Help
Forum Rules
Search
Login
Register
BCM Community
Bus Discussion
(Moderator:
Delco 50DN output
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Delco 50DN output (Read 2911 times)
Bob & Tracey
Full Member
Delco 50DN output
on:
January 18, 2013, 10:55:19 AM »
I understand this alternator is rated to put out 300 amps but what is the highest output under normal operating conditions?
Bob
Logged
Bob & Tracey Rice
1956 GMC PD4104-1611
Hero Member
Re: Delco 50DN output
Reply #1 on:
January 18, 2013, 11:44:29 AM »
12v version is rated at 300amps at 14v. It will only put out what is needed. The big alternator was used to power the two 1hp blowers for over the road A/C. On my bus, when the batteries get up fully charged, my alternator light comes on indicating a no charge situation. Hence, I simply run down the road with my headlights on all the time.
Wiring should be heavy enough to accommodate 300amps after startup. Good Luck, TomC
Logged
ol713
Sr. Member
Reply #2 on:
January 18, 2013, 11:58:54 AM »
Hi;
The 24v version on my MCI is rated at 225 amps.
What you have is a lot more amps than most folks
can use.
Good luck, Merle.
Logged
Hero Member
Reply #3 on:
January 18, 2013, 02:55:51 PM »
Tom,
When your batts are fully charged and there is no alt output why do you turn on the headlights?
This almost never happens to me because I connect the house batts to the bus alt for charging.
Also, I have my VR set to 13.75 amps as per the manual.
Logged
Kwajdiver
MCI-9 "Kwaj Diver"
Hero Member
Reply #4 on:
January 18, 2013, 04:07:04 PM »
If the MCI is rated for 225 amps at 24vdc, is there a way to tap 12vdc off it to charge the house batteries after the starting batteries topped off?
Bill W
Logged
Auburndale, Florida
MCI-9
Kwajalein Atoll, RMI
dickegler
Full Member
Reply #5 on:
January 18, 2013, 05:33:01 PM »
You can parallel a couple of 100 amp vanners, and get the job done. Not the cheapest way out.
If I was doing it again, I make the house bank 24volt.
Dick
Logged
dick egler atlanta, in 92 prevost/beaver conversion, N5333L
Kwajdiver
MCI-9 "Kwaj Diver"
Hero Member
Reply #6 on:
January 18, 2013, 05:38:59 PM »
Yes, but they cost almost $700.00 each.
Logged
Auburndale, Florida
MCI-9
hargreaves
1987 MCI 102A3
Sr. Member
Reply #7 on:
January 18, 2013, 08:53:36 PM »
I use a 100 amp vanner. I use a high capacity constant duty solonoid in the main line to the house batteries that energizes when the engine is started. Works well , I can run one ac while on the road without the genny starting up. Cheers Gerry
Logged
now as of Feb 2012 series 50 B400 . Sunshine Coast British Columbia
Print
Pages: [
1
Go Up
« previous
next »
BCM Community
Bus Discussion
(Moderator:
Delco 50DN output
