Author Topic: New graphic design for our MCI7  (Read 11912 times)
Offline chazwood
    • Thekempters
Re: New graphic design for our MCI7
« Reply #15 on: January 19, 2013, 10:20:37 AM »
Even the mail box has the right angle
1983 Eagle Bus Model 10
6V92
Thekempters.com
Offline RJ
  • Vantarè Conversion "Vivian"
« Reply #16 on: January 19, 2013, 10:55:50 AM »
Mike -
Here's an interesting idea to add to your design:  add a "center line" so that the entire graphic becomes a highway fading off into the distance.  Helps tie the entire travel theme together?
RJ Long
PD4106-2784: Donated to the Pacific Bus Museum
S14947: 1980 MC-5C Shell 6V92/HT-740
S13406: 1978 MC-5C Angola Coach - Swapped for vvv
M1001907: 1992 Prevost XL Vantarè Conversion 8V92T/HT-755 (DDEC/ATEC)
Cheney WA
Offline bansil
« Reply #17 on: January 19, 2013, 03:58:19 PM »
Mike -
That idea is what I kept "see-ing" and is why I made the comment I did.
It will look great when done for them
Doug
Mnt City TN
 Member of:
edeshields
« Reply #18 on: January 19, 2013, 06:42:28 PM »
Carl Epping at GM (who worked for the bus division) did a lot of research on whether car colors made car interiors hotter. Color wasn’t one of the most significant factors.
One of the problems with heat is that normal automotive glass is transparent to visible and near-infrared light (but opaque to UV), which heats up the interior. But the glass is opaque to far-infrared, which is what is re-radiated from the hot interior, and therefore traps the heat in the car. There are some newer glass treatments that cause it to be reflective to near-infrared, which helps considerably.
The car body acts as an insulator. Since the interior cannot re-radiate the heat back out, it has to conduct it through the body and windows to the outer skin of the car. The outer skin is then cooled as air passes over the car as well as radiating it off. The amount of cooling is heavily dependent on the temperature delta between the air and the car's surface. The car heats up until the incoming energy equals the outgoing energy.
Enjoy your color but tint your glass.
Offline Lin
  • Silver Donor
  • 1965 MC-5a
« Reply #19 on: January 19, 2013, 08:09:09 PM »
Sounds interesting, but I don't believe it as far as as bus goes. If only one side of the bus is in the sun with about 300 sq ft of surface that's heated to 140 degrees, it will be a lot hotter inside than if the surface temp was only 100 degrees.  I guess that someone else can work out the BTU difference, but it will be real.  Can anyone here say that they have not noticed the difference between wearing a black or white shirt when out in the hot sun?
Offline expressbus
« Reply #20 on: January 22, 2013, 11:38:46 AM »
Mike,
Looks real good. What design program were you using? Is it available on a low budget? I've been pencil whipping a design for our bus for a couple of years to no avail. Using electrons instead of pencil lead would be a refreshing change!
Will
Will Garner, Jr
Southern Pines, NC
1991 Prevost Conversion by Country Coach
Offline chessie4905
  • Platinum Donor
« Reply #21 on: January 22, 2013, 12:16:54 PM »
looks similar to the newest higher end rv's and toy haulers I saw at last fall's RV show at Hershey. They use a lot of metallic tan/bronze in place of the beige on black.
Offline Gary LaBombard
  • "Rustless Money Pit"
    • "Inspection & Repair Guide for Bus Conversions"
« Reply #22 on: January 22, 2013, 12:32:04 PM »
Mike,
I love your design posted, it sure is stricking and pleasant to look at.  I need to do this one day way, way in the future. Would your program you use be easy to reverse the colors you posted, (Make the Black white and the white Graphics Black.  That way there would be less black surfact to make contact with the sun and I am just curious how your design would look in reverse.  Do this only if you have the time, as I said your design sure is a pretty thing. Thanks.
Gary
Gary
Offline LowTide
« Reply #23 on: January 24, 2013, 11:25:22 AM »
Mike,
Will
Thanks!
I use a newer version of corel draw to design and then I use flexi sign pro for cutting my projects. I can also design in flexi, but just prefer corel. There are some download for trial, but these programs are not reasonably priced....hope that helps.
Mike and Lori
Sunny Phoenix Arizona
"1973 MCI MC-7 Challenger"
"Just Misbehavein' "
"A nation of sheep helps breed a government of wolves"
Offline LowTide
« Reply #24 on: January 24, 2013, 11:27:00 AM »
Thanks for the input, lots of good ideas! I will make some changes and post them to see if I like something else better.
Mike
Mike and Lori
Offline Dave5Cs
  • BCM Subscriber
Re: Re: New graphic design for our MCI7
« Reply #25 on: January 26, 2013, 09:16:59 AM »
Paint shop pro is good also and a lot cheaper.
Dave5Cs from Galaxy S III
"PATHFINDER"1979 MCI MC5Cs 6V-71,644MT Allison.
 1998 Jeep TJ & 2002 Buick Century, Roseville,CA
Congressmen should wear uniforms, like NASCAR drivers, so we could identify their corporate sponsors
