BCM Community
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
BCM Home
Forum
Help
Forum Rules
Search
Login
Register
BCM Community
Bus Discussion
(Moderator:
S60 on craigslist
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: S60 on craigslist (Read 5451 times)
Timkar
Sr. Member
S60 on craigslist
on:
January 23, 2013, 07:51:44 AM »
Just in case someone in the NW is looking to repower.....
http://seattle.craigslist.org/oly/pts/3521591377.html
Logged
Cawston, British Columbia
Hero Member
1980 MCI MC-5C
Re: S60 on craigslist
Reply #1 on:
January 23, 2013, 08:16:46 AM »
And he's willing to trade for firewood!
Logged
John316
Hero Member
MCI 1995 DL3, DD S60, Allison B500.
Reply #2 on:
January 23, 2013, 11:47:38 AM »
Can't go wrong. It was just rebuilt. No problem
If I lived closer I might actually trade him for it, just to play with it.
Logged
expressbus
Full Member
Reply #3 on:
January 23, 2013, 01:27:35 PM »
Friend did a engine swap to an Eagle. Detroit was called and the friend was told no way was Detroit going to give assistance to someone building a hot rod bus that is 50 years old - click. That was the sound of the phone being hung up - fast too!
Good luck with Detroit. The friend had to make up his own custom harness.
Logged
Will Garner, Jr
Southern Pines, NC
1991 Prevost Conversion by Country Coach
hargreaves
1987 MCI 102A3
Sr. Member
Reply #4 on:
January 23, 2013, 02:39:42 PM »
Making a harness is easy If he as both ends all you need is about 40 feet each of about 32 different colored wires some connectors solder and shrink tubeing. Cheers Gerry
Logged
now as of Feb 2012 series 50 B400 . Sunshine Coast British Columbia
Hero Member
Reply #5 on:
January 23, 2013, 03:58:56 PM »
Eagles came with series 60 in the late 90' only problem DD has is they were never certified with a drop box but getting help is not a problem Williams will give you phone numbers for assistance
Logged
twostick
Newbie
Reply #6 on:
January 23, 2013, 07:14:06 PM »
These guys make retro-fit harnesses for Cat Cummins and Detroit engines.
http://mawkindustries.com/
Kevin
Logged
Hero Member
Reply #7 on:
January 24, 2013, 08:21:43 AM »
i think the required wiring harness is going to be pretty low on the list of issues when stuffing a Series 60 into a bus. You have to deal with motor mounts, air intake piping, transmission interface, and a whole host of other issues.
Personally, I don't think I would buy that engine unless you want to spend a lot of time getting it ready to go into your bus. It looks a little rough, but of course a fresh coat of spray paint can also be hiding a whole bunch of issues too.
Logged
Hero Member
Reply #8 on:
January 24, 2013, 11:42:32 AM »
Would be better just to buy the complete wrecked truck. When you buy a cut out like this, who knows what you're missing. I don't see the gas pedal? Then you'll see exactly how everything is supposed to be hooked up.
One of the main things you have to change on a Series 60 is the oil pan. The truck oil pan is just to deep for a bus. Detroit makes a shallow pan for buses. It is a good idea also to change from the one piece plastic valve cover to the two piece aluminum. It makes for easier removing of the valve cover once the engine is in place. Good Luck, TomC
Logged
dickegler
Full Member
Reply #9 on:
January 24, 2013, 03:22:31 PM »
Hi all,
will any of the marine oil pans work in a bus application? I know at least they are shallow.
Dick
Logged
dick egler atlanta, in 92 prevost/beaver conversion, N5333L
Ed Brenner
Sr. Member
Reply #10 on:
January 24, 2013, 05:55:36 PM »
By the time you buy the oil pan, pickup tube and brackets, oil pan gasket and special pan bolts
you will have eaten up a $1000 bill pretty good.
I just did it , starting the re-power in my Eagle with a 60 series. The engine is the easy part!
That ain't a bad price for an engine, turbo and ECM cost you that. I could use it for spare parts if closer.
ED
Logged
Ed Brenner
77 Eagle 05 Murrells inlet, SC
" While We're At It " A Busnut's most costly Phrase !!
Print
Pages: [
1
Go Up
« previous
next »
BCM Community
Bus Discussion
(Moderator:
S60 on craigslist
