Author Topic: MCI MC9 exterior rivet replacements?  (Read 5962 times)
Offline Jnbroadbent
« on: January 24, 2013, 04:56:31 PM »
Got two 4x8 sheets of 16ga aluminum, I was looking to find the same sized rivets as the stock ones. Anyone have a clue? Thanks.
Jon
1980 Mc9 w/ veg oil
8v71
Jacksonville Fl
Offline Tikvah
    • Dave & Amy
Re: Re: MCI MC9 exterior rivet replacements?
« Reply #1 on: January 24, 2013, 05:22:15 PM »
Steel rivets or aluminum?
Sent from my DROID RAZR HD using Tapatalk 2
1989 MCI-102 A3
DD 6V92 Turbo, Alison
Tons of stuff to learn!
http://dave-amy.com/
Offline buswarrior
  • '75 MC8 8V71 HT740
« Reply #2 on: January 24, 2013, 08:37:15 PM »
Who is the regular advertiser in the magazine that sells every kind of rivet?
Mag is remote to my location currently.
Offline Jnbroadbent
« Reply #3 on: January 24, 2013, 08:46:50 PM »
Aluminum
Jon
1980 Mc9 w/ veg oil
8v71
Jacksonville Fl
Offline ol713
    • ol713
« Reply #4 on: January 24, 2013, 08:50:38 PM »
Hi;
    Try Byler rivet @ 800/325-3147.
    They are in Irving, Texas and advertise
    regularly in BCM.   They should have any
    thing you want in rivits and tools to
    install them.
                          Gook luck,  Merle.
Offline Sam 4106
« Reply #5 on: January 25, 2013, 04:36:37 AM »
You could also try FSI (Fastener Systems International) 800-344- 2393, another advertiser in Bus Conversions Magazine. I had good luck with them.
Good luck, Sam
Offline Tikvah
    • Dave & Amy
« Reply #6 on: January 25, 2013, 02:00:45 PM »
Aluminum
This question of steel or aluminum has haunted me since I did my side panels.  Aluminum rivets will not be compatible in the steel subframe.  Steel rivets will not be compatible with the aluminum panels.
Byler Rivet sent me Steel  ???
1989 MCI-102 A3
Offline Jnbroadbent
« Reply #7 on: January 25, 2013, 02:38:49 PM »
I am a bit curious now, I know the interior panels rivets are aluminium but I don't remember abou the exterior. When I'm home I'll pop one out and check.
Jon
1980 Mc9 w/ veg oil
8v71
Jacksonville Fl
Offline bevans6
  • 1980 MCI MC-5C
« Reply #8 on: January 25, 2013, 02:49:34 PM »
with aluminium and steel, aluminium corrodes preferentially.  Steel rivet will corrode the aluminium skin, aluminium rivets will kind of loosen up in the steel structure.  It can take a really long time - I have a 32 year old race car in my shop with aluminium tub riveted to a steel subframe and it looks like new...  I personally prefer aluminium rivets in stainless or mild steel.  Using a really good paint or even double-sided tape between the steel and the aluminium sheet works really well.
Offline Jnbroadbent
« Reply #9 on: January 27, 2013, 08:35:48 AM »
Yup, positive they are aluminium solid buck rivets.
Jon
1980 Mc9 w/ veg oil
8v71
Jacksonville Fl
Offline Larry B
« Reply #10 on: January 27, 2013, 07:07:25 PM »
  I rivetted aluminum to steel frame and as Brian suggested I used the sticky mastic that  comes in a roll. I am assuming you are going to use pop rivets. IF this is on a upper wall (house or living enclosed area) I would recommend the closed rivets. Some places refer to these as blind rivets. One day when I was working on the outside I had to go inside to get a tool. While walking past the sheet I had just rivetted I could see daylight though the center of a rivet. I think what happens is when the pop rivet breaks it is with such force that the head of the rivet flys back and goes right out the back end. I was able to go over each rivet from the inside with a silcone gun . But after this i switched to closed rivets. It is amasing how much water can get though a small hole. Don't want water inside living wall area. If this is on a bay door Either type should be fine. This is only my personal choice.
    Larry B
1977 MCI-5B---
8V71- 4speed man
Offline junkman42
« Reply #11 on: January 28, 2013, 07:15:53 AM »
Byler sells a closed head rivet made for repairing airstream trailers.  I think maybe called bulbtite.  These are not pop rivets but rather expanding back style and have to be trimmed after pulling.  Look like driven rivets after trimming with the proper tool!  John L
Offline tekebird
« Reply #12 on: February 01, 2013, 02:10:08 PM »
I have a MCI rivet board, with part numbers.......they should be available from MCI
Offline Chuck Hancock
  • 1986 Prevost Liberty
« Reply #13 on: February 04, 2013, 08:45:58 AM »
without seeing them, I would bet they are 3/16 stainless
Chuck & Beth Hancock
Ridgefield,  Ct
Offline Jnbroadbent
« Reply #14 on: February 04, 2013, 09:34:00 AM »
Nope, 1/4" aluminium
Jon
1980 Mc9 w/ veg oil
8v71
Jacksonville Fl
