June 23, 2018, 03:06:29 PM
Author Topic: lexan window above front window broke  (Read 2774 times)
Offline sledhead
« on: March 03, 2013, 03:26:13 PM »
My lexan window above the front window (1990 mci 102c3 ) started to cup or warp over the last few years and I added silicon at the rubber and the lexan as the lexan would not stay in the rubber.Now that I have time to repair it I removed all the silicon ,cleaned the rubber.But when I tried to reinstall it I could not get the warp out of it and I cracked it  :'( . Now I have looked on line at nimco for a new or used one. I will call them on mon. How much will it cost? and is it because of age that the old one warped?  Any ideas
thanks     dave
dave , karen
Offline RJ
Re: lexan window above front window broke
« Reply #1 on: March 03, 2013, 06:18:57 PM »
Dave -
Several recent posts have said that since Nick retired, Nimco doesn't sell bus parts anymore.  But try them anyway. . .
Sam Caylor @ Caylor Supply might be another source, or you could always call MCI Service Parts - they might actually be your best bet.
RJ Long
PD4106-2784 No More
S13406 1978 MC-5C Converted
6V71/MT-644
S14947 1980 MC-5C Shell
6V92/HT-740
Cheney WA
Offline Jeremy
  • 1987 Bedford Plaxton
    • Magazine Exchange
« Reply #2 on: March 03, 2013, 07:38:37 PM »
Polycarbonate (Lexan) is easy to buy and can be cut and shaped with regular tools - I'd look at the option of making a replacement window yourself as well as buying one
Offline sledhead
« Reply #3 on: March 03, 2013, 09:00:26 PM »
What about 18 gage satin coat gal. like I used on the skin over the side windows.Its not like you can see through it .Thats were the tv, a/c is. Cut to size paint and install in the rubber used for the lexan?         dave
dave , karen
Offline Brian Diehl
    • www.brihil.com
« Reply #4 on: March 04, 2013, 02:54:49 AM »
I had the same problem with the overhead window on my 96A3.  I put in a piece of alucabond.  I had it cut and power pressed into the right shape based upon the old piece of lexan.  I love the result and know it won't deteriorate in the UV rays.  Plus I have no more water leakage and it is quieter to boot.  See if you can find a local sign place or commercial building exterior provider.  The alucabond is used on commercial building exteriors and on signs.  Mine cost me $90.  You will not like the price of a new window!
Offline Gerry H
  • 1992 Prevost LeMirage XL-40 8V92 740 Allison
« Reply #5 on: March 04, 2013, 03:04:46 PM »
  I replaced my Prevost driver's side lexan dual pane with real glass. Prevost quit using Lexan due to the many problems that comes with it.
I would take your lexan panel to an auto glass shop and talk with them. Good Luck Gerry H
Forest Lake, Minnesota
Land of 10,000 mosquitoes and a few cool buses
