Author Topic: Oil filters - manufacturer recommendations?  (Read 9183 times)
Offline rv_safetyman
  • Jim Shepherd
    • Bus Project Details
« on: March 03, 2013, 08:27:33 PM »
I typically get my oil filters at the Detroit dealer.  However, they are about 50 miles away and I am thinking about ordering them on line.
For a Series 60 the Detroit number is:  23518480.  That crosses to a Wix 51971 and Donaldson P552100  and Baldwin B495.
So, my question:  what do you guys consider to be a good filter?  I have always heard that Wix is the best and I have heard so many bad things about Fram, that I will not consider them.
Do any of you have a favorite on-line source?
Jim Shepherd
Evergreen, CO
Offline Lin
  • 1965 MC-5a
Re: Oil filters - manufacturer recommendations?
« Reply #1 on: March 03, 2013, 09:12:20 PM »
Just based on my uninformed prejudices, I would go with Donaldson, Wix, and Baldwin in that order.  All three are probably fine though. I think that Napa is made by Wix.  As you mention, Fram does not usually do well in tests.
Offline bevans6
  • 1980 MCI MC-5C
« Reply #2 on: March 04, 2013, 03:02:23 AM »
I use Donaldson, from my local truck store.
Offline sledhead
« Reply #3 on: March 04, 2013, 04:56:39 AM »
Wixx all the way around fuel,oil,trans,rad and the auto parts place I use delivers in a couple of hours                          dave
dave , karen
Offline goutoe
« Reply #4 on: March 04, 2013, 05:13:09 AM »
Baldwin filters are made in Kearney Ne. where I live, I have toured the plant and seen first hand the quality of work that goes in to these filters, made a believer out of me.>>>> John.
John & Linda 1977 AM General 6V92 turbo Detroit 3 Speed allison, 40 ft.
Offline Low Class
« Reply #5 on: March 04, 2013, 06:23:17 AM »
Fleetgard gives me that warm fussy feeling.  Bought a case of six, with the synthetic media, from ebay at an excellent price.
Jim Keefauver/1985 Wanderlodge PT36/6V92TA/MT654CR/East Tn.
Offline Ed Hackenbruch
« Reply #6 on: March 04, 2013, 09:52:23 AM »
 Just got back from getting my filters at Napa, locally they have their Gold Filter sale going on.  Got my fuel filters for $4.76 and $4.91 and the oil filter for $2.78  Got my 4 air filters for  $10.31 each.  All set for my yearly service.
Used to own a 1968 MCI 5A with 8V71 and Allison MT644 transmission.
« Reply #7 on: March 04, 2013, 02:19:00 PM »
Donaldson makes the Detroit filters. I've always used Donaldson.
With the new Detroits 50,000mi oil change, Baldwin filters had a tendency towards falling apart before the 50,000mi. I would think that might also apply to a bus sitting for several weeks at a time.  Good Luck, TomC
  • Jim Shepherd
« Reply #8 on: March 04, 2013, 04:04:12 PM »
Thanks everyone.
When I was looking, the Donaldson was less expensive than Wix.  That made me nervous.
With your input, I ordered the Donaldson oil filters and an air filter (about $20 or more savings over Wix).  I did not do a large search, but this company seemed to be a good source:
http://apartsdepot.com
Jim Shepherd
Evergreen, CO
Offline Boomer
« Reply #9 on: March 04, 2013, 04:13:25 PM »
I'm curious Jim, what kind of air filter are you using?  Reason I ask is that the Donaldson ECO series , once installed should last darn near a lifetime at the miles we put on our motorhomes if you don't run off road.  I run one on the Eagle with a filter minder (which I am somewhat skeptical of) and also have one on the Silverside.  Just wondering.
'81 Eagle 15/45, NO MORE
'47 GM PD3751-438
'65 Crown Atomic, NO MORE
Vancouver, WA USA
Offline akroyaleagle
« Reply #10 on: March 04, 2013, 04:54:31 PM »
Jim,
I get mine here:
https://www.filter1.com
You may have to establish an account. It's painless.
I don't think that any of us have to worry about the quality of a name brand filter. To me it's the same as Ford vs Chevy.
These filters are manufactured to handle heavy equipment in harsh conditions. We are neither.
Joe
Joe Laird
'78 Eagle
Sioux Falls, South Dakota
Joe Laird
'78 Eagle
Offline Lin
  • 1965 MC-5a
« Reply #12 on: March 04, 2013, 05:41:49 PM »
Ed, after reading your post, I immediately called my local Napa.  Oil filter is $30. plus here.
Offline Chuck Hancock
  • 1986 Prevost Liberty
« Reply #13 on: March 04, 2013, 05:55:14 PM »
I use Wix as they were recommended by Prevost.  I know I over kill on oil maintenance but I chage the oil and filters at 5000 miles.  With the low mileage per year I believe it is the single best maintence thing that I do.  I try to do the service in the spring so as to get any condensation and have it fresh for the summer.  I also always have Detroit desiel do an oil analysis.  They have maintained records on my coach for years and are a good way to catch any early problems.
Chuck & Beth Hancock
Ridgefield,  Ct
  • Jim Shepherd
« Reply #14 on: March 04, 2013, 07:11:23 PM »
Sure Joe, NOW you come up with an online source  ;D
Here are the oil filters I bought:
http://apartsdepot.com/detail.cfm?part=1814111
Your source has a good price for the Wix filter.
Mark, I am using this air filter:
http://apartsdepot.com/detail.cfm?part=1688715
My current air filter is a Wix 46883 and that crosses to the Donaldson (above).  This is the filter for the Freightliner I got the first engine from.  I took the cowl mount housing and modified it for the bus.  I am using the standard passenger side Eagle opening (larger than standard for the Houston Metro buses).  I looked a while back and that filter has among the highest flow ratings as I recall.
I also use a filter minder and it always reads fairly high restriction.  That said, the filter generally has a large amount of dust (I don't take it on dirt roads, but the pull outs often have loose dirt that is kicked up by the bogies and rear wheels) after each trip.  I blow out the dust  :o :o with open ended 3/8 DOT tubing.
For a long time, I have wanted to put a water manometer on both the intake and exhaust sides of the engine - can't seem to find the time to hook up a simple jury-rigged system.  The priority drops down when I consider how strongly the engine pulls - doesn't seem like it could be too bad.  In addition, making either end of the system more free-flowing would be a major modification.
« Last Edit: March 04, 2013, 07:14:51 PM by rv_safetyman »
Jim Shepherd
Evergreen, CO
