Author Topic: Checking fluid in VS2-8  (Read 893 times)
Offline Sipapu
« on: March 29, 2013, 05:19:35 PM »
What is the proper way to check this fluid.  It has Rotella in it - is that a good choice?  I run Rotella 40 wt in the motor.
Rick "Adventure" Reese
New owner - 1969 GMC T8H5305a-020
This is the bus Sandra Bullock did NOT trash in the movie, Speed
Offline treeplanter
  • the grey ghost,1971 GMC 5305A
Re: Checking fluid in VS2-8
« Reply #1 on: April 26, 2013, 10:20:01 AM »
I have the same tranny, researched before i changed the fluid most of the info i found say's to use delco ATF not motor oil and thats what it had in it when i drained it/ Mine has two skinner valves mounted on the top end of tranny, not sure what they do yet have only driven her once just wondering how many yours has and if you know their purpose?
Timothy
Offline Utahclaimjumper
« Reply #2 on: April 26, 2013, 12:46:55 PM »
 The skinner valves control the shifter (probably an air unit).>>>Dan   And it should have ATF in it, but 10 weight oil will work well also
Utclmjmpr
 EX 4106 (presently SOB)
Cedar City, Ut.
 72 VW Baja towed
