June 23, 2018, 06:43:15 AM
Author Topic: 1983 6v92t 24v starter .. positive or negative ground?  (Read 5139 times)
Offline Darkspeed
« on: March 31, 2013, 04:14:36 PM »
 Ok i saw this thing start but i dont know which way the cables were on the starter.
connecting negative ground the solonoid clicks but starter does not turn.
Could it be positive ground??
It's all math and metal...
Offline Purplewillie
Re: 1983 6v92t 24v starter .. positive or negative ground?
« Reply #1 on: March 31, 2013, 04:17:10 PM »
It's broken, ill give you your money back
Lol
Sorry I don't have a real answer
Mark
Mark & Char
1976 P8M4905a 8v71 v730
British Columbia Canada
« Reply #2 on: March 31, 2013, 04:21:52 PM »
be sure to hook the 2 batteries from + to -on each 12 v battery to get the 24 v then try it
Offline Darkspeed
« Reply #3 on: March 31, 2013, 04:29:47 PM »
yes i have two bats to get 24v and sol clicks but no starter.. letting the batts charge up a while to see if its just a low voltage issue.
Do some of the 24v starters as late as 83 use positive ground?
Offline tekebird
« Reply #4 on: March 31, 2013, 04:56:12 PM »
should not be positive.
what was the BAtt voltage when you tried this?
you can have a battery that shows good voltage but does not have the load capacity to crank
Offline Darkspeed
« Reply #5 on: March 31, 2013, 06:10:00 PM »
ok im an idiot the wire to the starter was loose - cranks and runs -that was untill i ran it out of diesel
how do you prime a 6v92? keep cranking?
« Reply #6 on: March 31, 2013, 06:16:36 PM »
No you will use up the starter remove the filters and fill with fuel or remove the plug on the primary filter and pump fuel through it either with a electric pump,squeeze bottle or garden sprayer
Offline Darkspeed
« Reply #7 on: March 31, 2013, 06:18:40 PM »
ok thanks il try filling the filters
Offline Don4107
« Reply #8 on: March 31, 2013, 06:22:44 PM »
<ok im an idiot the wire to the starter was loose - cranks and runs -that was untill i ran it out of diesel
how do you prime a 6v92? keep cranking?>
Not unless you want to replace the starter again.  Try filling the fuel filters and then try it.  If you cranked it after it stopped you will probably have to put some pressure to the system.  I recommend an inline fuel pump.  Makes priming a snap when/if you run out and makes changing filters a snap.
Don 4107 Eastern Washington
1975 MCI 5B
1966 GM PD 4107 for sale
1968 GMC Carpenter
« Reply #9 on: March 31, 2013, 06:23:31 PM »
It may take more than 1 time filling the filters fwiw
Offline Darkspeed
« Reply #10 on: March 31, 2013, 06:39:01 PM »
leave it inline all the time or just to prime?
What pump do you recomend?
Offline wg4t50
« Reply #11 on: March 31, 2013, 06:55:42 PM »
Ya gotta get fuel into the fuel pump, a dry pump dont work.
MCI7 20+ Yrs
Foretravel w/ISM500
WG4T CW for ever.
Central Virginia
« Reply #12 on: March 31, 2013, 07:02:15 PM »
Don Fairchild NEVER uses a primer pump-he says it is to easy to blow the pump seals. I watched him prime my engine. He took off the fuel lines one at a time and filled them with fuel. Then filled the filters with fuel also. Then cranked. He repeated this process 3 times and on the fourth try it started. Don said that is typical. Good Luck, TomC
Offline Iceni John
« Reply #13 on: March 31, 2013, 07:17:22 PM »
I bought a Facet-Purolator pump for this purpose, but I made sure to get one for carburetted cars, not for cars with fuel injection.   The difference is the pump's output pressure  -  mine is only 1 or 2 PSI, but EFI pumps are a lot more (40-ish?).   I've used it once when I got air into my Racor 900FG's fuel bowl, and after running the pump for a few minutes the engine started right up.   Easy!
2kW of tiltable solar on the roof.
« Reply #14 on: March 31, 2013, 08:02:48 PM »
Takes a lot pressure to blow a seal in one of the old DD fuel pumps they are double sealed took over 100# of air when I did a little test, 20# is not going to blow a 70#psi seal
I guess Donald blew one of the old types years ago he doesn't forget somethings lol
