Author Topic: 730 trans for a 4106  (Read 4516 times)
Offline jimsflx
« on: April 11, 2013, 11:51:50 AM »
i want to change over to auto 65 gm 4106. any one have one? and what is the differance between730 and 731.is it the gearing? thanks jim
jim&roenie seagraves sebring fl. 4106-3083
Offline wildbob24
Re: 730 trans for a 4106
« Reply #1 on: April 11, 2013, 11:42:46 PM »
Jim,
There's one on eBay: http://tinyurl.com/AllisonV730
The listing says it's for right turning motors, but then says it came from a mid 70's bus with an 8V71, which was most likely a lefty like yours, so there may be some confusion on the seller's part as to what he actually has. Shipping may be an issue depending on where you are.
You can also google "allison V730 for sale" and find some more.
The 731 is the electronically controlled version of the 730.
Bob
P8M4905A-1308, 8V71 w/V730
Custom Coach Conversion
Greenville, GA
Offline RJ
  • Vantarè Conversion "Vivian"
« Reply #2 on: April 12, 2013, 12:02:46 AM »
Jim -
Be aware that one of the negatives about installing the V-730 in your 4106 is that you're going to lose 1 - 2 mpg in fuel economy, and approximately 5-7 mph of top speed.  And your going to have to watch the temp gauge more closely.
Of course, the advantage is all you have to do is "stab & steer", rather than actually "drive" the coach.
Best if you can find a transit with either a V6 or V8 attached to the transmission, that way you have all the parts for the swap.  Might be cheaper to buy the whole bus, rather than just the tranny.
You'll have to cut a big hole in the engine bulkhead - make sure you reinforce it when you do.
Please take a minute to edit your profile with a signature line including information similar to mine below.  By doing so, we can better help you find parts and service in your area - you might even find out there's another busnut not too far away!
RJ Long
PD4106-2784: Donated to the Pacific Bus Museum
S14947: 1980 MC-5C Shell 6V92/HT-740
S13406: 1978 MC-5C Angola Coach - Swapped for vvv
M1001907: 1992 Prevost XL Vantarè Conversion 8V92T/HT-755 (DDEC/ATEC)
Cheney WA
« Reply #3 on: April 12, 2013, 08:27:11 AM »
Pull the 8V-71 and 4spd and install a 6V-92TA (either mechanical or electronic) and the V730. The engine is 400lbs lighter and shorter-giving you some room to work with it. Lot's of 6V-92's around from transit buses. Good Luck, TomC
Offline jimsflx
« Reply #4 on: April 12, 2013, 01:49:51 PM »
thanks rj,wildbill,and tom c. i have to replace the clutch so i thought it mite be the time but after talking to luke i think i will keep the 4 speed. tom c the8v71 only has 16,000 miles on it and it does not leak or smoke.  thanks jim
Offline baker4106
« Reply #5 on: April 12, 2013, 03:53:20 PM »
Jim, are you still planning to be in Michigan this summer?   Larry B. 4106-0038
Offline gus
« Reply #6 on: April 13, 2013, 03:31:49 PM »
All RJ says is true but the real advantage is when starting when stopped on a steep incline, I just don't have to worry about that any more and it is a real relief.
Backing up as slowly as you like is great also.
As for fuel mileage, these things use so much fuel that a few more gal/mi just doesn't matter much!
I would never go back even though shifting was usually a lot of fun.
Offline MysteryBus
  • 1965 GM 4106 8v71 4 speed Spincer
« Reply #7 on: April 14, 2013, 08:40:34 AM »
I feel your pain with backing up, and really don't like where they put the reverse!
I mean it, youve got a nice place. Its not
 every man that can live off the land, you know.
 You do your own thing in your own time.
 You should be proud. - Captain America ;)
Offline uncle ned
    • Visit: Busconversionstuff.com
« Reply #8 on: April 14, 2013, 06:02:15 PM »
A man to all of the things about the 730 conversions
uncle ned
4104's forever
6v92 v730
Huggy Bear
Offline Barn Owl
  • Roanoke, VA
  • PD4106-1063 "Wheezy Bus"
« Reply #9 on: April 20, 2013, 07:24:43 PM »
I love the auto. It allows access to the places I like to take the bus, like my driveway. LOL
« Reply #10 on: April 21, 2013, 10:06:04 AM »
I can tell you, you'll simply love the auto trans. Takes all of the tension out of driving-especially starting on a hill. If you want to keep the 8V-71, turbocharge it. I went from 300hp and 800lb/ft torque with N65 injectors to 375hp and 1125lb/ft torque with 7G75 injectors. And what a difference in performance! I have 4.56 rear end with 11R-24.5 rubber. I cruise at 1850rpm which is 58mph. My fuel mileage is still the same (4.5-6.5), but I don't mind with the performance and no smoking at altitude. Turbocharging really wakes up the 8V-71. Good Luck, TomC
Offline jimsflx
« Reply #11 on: April 21, 2013, 11:46:29 AM »
well guys just put a new clucth and parts in  so am going to stick with the four speed. tomc do not need a turbo this thing is a rocket. thanks jim
Offline Purplewillie
« Reply #12 on: April 21, 2013, 04:52:03 PM »
I want Toms motor, aren't you done with it yet?
Mark & Char
1976 P8M4905a 8v71 v730
British Columbia Canada
