Author Topic: 8 Volt Batteries  (Read 5850 times)
  • Gold Donor
8 Volt Batteries
« on: May 06, 2013, 06:29:47 AM »
Anyone using 8 volt batteries for a 24 volt house system I helped a friend here in Texas change from 6 volt golf cart batteries to the 8 volt he had a 12 battery bank.
 We tied 3- 8 volt batteries in series for the 24 volt then we tied the 3 strings (9 batteries) in parallel going to the inverter doing away with 3 of 6 volt he lost a few amp hr but saved on 3 batteries
? has anyone here tried this and will it work it seems ok to me and the inverter seems to have no problem with the charging  I am looking for future pit falls if any what say you electrical guys
Offline Ed Hackenbruch
Re: 8 Volt Batteries
« Reply #1 on: May 06, 2013, 06:36:43 AM »
 I am not an electrical guy but it seems to me that it should be fine. My only questions are where do you find 8v batteries and what is their usual application and cost?  Some place like Interstate Batteries or a farm supply store? Used in tractors or mowers?
Used to own a 1968 MCI 5A with 8V71 and Allison MT644 transmission.
Offline Dave5Cs
  • BCM Subscriber
Re: Re: 8 Volt Batteries
« Reply #2 on: May 06, 2013, 06:47:38 AM »
Ed you can get them in a golf cart repair shop or sales place. Also commercial battery place as well as most truck parts houses.
Clifford that should work depending on what he is running from those circutes.
Dave5Cs from Galaxy S III
 1998 Jeep TJ & 2002 Buick Century, Roseville,CA
Congressmen should wear uniforms, like NASCAR drivers, so we could identify their corporate sponsors
  • Gold Donor
« Reply #3 on: May 06, 2013, 07:05:01 AM »
He bought his from Costo paid under a 100 bucks ea and a $81.00 core charge total for the 9 and sold his 12 -6 volt at a recycling place for $25.00 each for a total of $300.00 took a bite out of the total cost.
He ended up with a bank of 412 amp hrs he says that more than enough losing a 100 amp hr was not a big deal for him
« Last Edit: May 06, 2013, 09:06:34 AM by luvrbus »
Offline uncle ned
    • Visit: Busconversionstuff.com
« Reply #4 on: May 06, 2013, 08:42:23 AM »
Clifford
 boy does that bring back bad memories   had to use them a few years ago to start old flathead fords and some of my hot rod 6  chev.
In our 0 degree winter mornings. Also using alcohol  or spring water to keep from freezing up.
uncle ned
4104's forever
6v92 v730
Huggy Bear
Offline bevans6
  • 1980 MCI MC-5C
« Reply #5 on: May 06, 2013, 09:34:15 AM »
three eight volt batteries are the same, electrically, as two twelves or four sixes, but he won't be able to center-tap for 12v.  An equalizer would probably be able to supply some 12v at fairly low current to run a radio or something like that.
  • Gold Donor
« Reply #6 on: May 06, 2013, 10:04:26 AM »
He doesn't need a center tap his 24 volt system is for house only (110v through a inverter) his Eagle is a 12 v chassis system
Offline Lin
  • 1965 MC-5a
« Reply #7 on: May 06, 2013, 10:24:33 AM »
My question would be why, not if you can, use 8v batteries.  One could use any combination of theoretic battery voltages to get to 24v, but is there some advantage to using 8v?
Offline bobofthenorth
    • R.J.(Bob) Evans
« Reply #8 on: May 06, 2013, 11:47:58 AM »
The guy across the dock from me right now has several 1.5 (or possibly 3) volt batteries that he is connecting as a house bank.  Apparently they have some telecom application.  They are huge - roughly 2 feet tall by maybe 14 x 16.
R.J.(Bob) Evans
My website
Contrary to popular belief, wise men do not learn from their own mistakes
They learn from the mistakes of others.
Offline buswarrior
  • '75 MC8 8V71 HT740
« Reply #9 on: May 06, 2013, 02:47:57 PM »
Big Transit here uses the 8 volt batteries in banks to make 32 volt banks for the subway cars.
Offline belfert
« Reply #10 on: May 06, 2013, 04:21:20 PM »
The only real advantage I see to 8 volt batteries is being able to use one less battery per 24 volt bank.
Online chessie4905
  • Platinum Donor
« Reply #11 on: May 06, 2013, 06:35:32 PM »
what if he used 10 instead of 12 golf cart batteries. Would total output equal the 8 volt setup? What about total cost compared to the 8 volters?
Offline Sam 4106
« Reply #12 on: May 06, 2013, 06:45:13 PM »
Chessie,
You need four 6 volt batteries to make 24 volts. So, you need multiples of four to expand a 24 volt system, such as eight, twelve and so on. Ten 6 volt batteries won't work in a 24 volt system.
Good luck, Sam
Offline pvcces
« Reply #13 on: May 06, 2013, 10:06:59 PM »
Cliff, we have been using them for years in our boat which has a 32 volt house bank. Hell, when I had some low start bank batteries, they even started the main with no difficulty. We still have two in our battery storage area.
They should work fine if they are deep cycle.
Tom Caffrey PD4109-2576
Suncatcher
Ketchikan, Alaska
Tom Caffrey PD4106-2576
Suncatcher
Ketchikan, Alaska
Online chessie4905
  • Platinum Donor
« Reply #14 on: May 08, 2013, 05:57:50 AM »
oops ::) wasn't thinking;what if he used 8-6 volt batts. How much lost capacity compared to the 8 volters. BTW, how much dead weight are 12 golf cart batteries?
