June 25, 2018, 06:06:13 AM
Author Topic: Overheating questions...  (Read 7945 times)
Offline harleyman_1000
    • My bus
Re: Overheating questions...
« Reply #15 on: May 16, 2013, 05:10:53 PM »
You definitely need ALL the shroud or loose a good deal of cooling efficiency. I finally replaced/fabricated a small 8 inch long piece on front of shroud (previous person removed/discarded to make cooling fan removal easier) and it stopped getting too hot on long pulls. 6-71 turboed.Keep engine wound up  on long grades; no lugging. Accurate temp gage and tach. With clean rad, full shroud, and even larger injectors, 04's shouldn't have heating issues
Why shouldn't a 04 have overheating problems?
Scott
St.Louis Missouri
Offline gus
« Reply #16 on: May 16, 2013, 05:15:09 PM »
You lucked out, the vinegar treatment often causes leaks in old rads.
Offline chessie4905
« Reply #17 on: May 16, 2013, 07:38:56 PM »
the stock horsepower engine or n-65 shouldn't haven't any cooling problems with a good condition cooling system. They overbuilt that model.
    • My bus
« Reply #18 on: May 17, 2013, 05:46:02 AM »
 Did all the 4104's have the same cooling system?
Scott
St.Louis Missouri
« Reply #19 on: May 17, 2013, 07:02:47 AM »
Any 4104 with a 6L-71 will overheat if lugged they run the coolest at about 1600 to 1700 rpm lot of heating problems can be controlled by the right foot  :o
    • My bus
« Reply #20 on: May 17, 2013, 09:15:19 AM »
 Would the 4106 8-71 cool the same?
Scott
St.Louis Missouri
Offline Red Rider
  • God put me here to accomplish certain things--- I'm so far behind I'll never die.
« Reply #21 on: May 17, 2013, 02:22:40 PM »
Clifford sure is right on this one. My 06 gave me heating problems because the Vernatherm would not close. After I fixed that everything else worked perfectly. Watch the mirror and lift when you see any black smoke. If your rig won't stay at the desired speed, then down shift.I just came back to the Utah mountains from Clifford's which has many severe long grades and no heating problems at all.
Mike AKA; Red Rider 4106-1885
