Author Topic: fuel tank Size  (Read 3457 times)
Offline jaybe_2
fuel tank Size
« on: November 26, 2006, 05:52:56 PM »
I have a 1985 Prevost XL. I'm looking to find out how big the fuel tank is. I have tried to measure it through the access hole but had no luck, could not get the tape down the side.
Offline muddog16
  • Example is more powerful than reproach. ~Aesop
    • Prevost LeMirage Conversion
Re: fuel tank Size
« Reply #1 on: November 27, 2006, 03:02:59 AM »
Jay unless someone removed the infomation plate, wipe the road grime off it should be on the top right of the tank, the gallons will be stamped on that plate.
Pat
1982 Prevost LeMirage
8V92TA/HT754
Offline jaybe_2
Re: fuel tank Size
« Reply #2 on: November 27, 2006, 04:11:57 AM »
Thanks for the help. I will check that today.
Offline rip
Re: fuel tank Size
« Reply #3 on: November 27, 2006, 05:10:27 AM »
Jay,I also have an 85 and mine has a 165 gal. tank
Offline jaybe_2
Re: fuel tank Size
« Reply #4 on: November 27, 2006, 03:47:03 PM »
Well no luck finding the information plate. I dint even see a spot were it would have been. I will just wait till I rip the bus apart and measure it then. Thanks Rip I hope mine is that big also.
« Last Edit: November 27, 2006, 03:51:28 PM by jaybe_2 »
Offline eglluvr
  • Jr. Member
  • The Quest is But The Beginning...
Re: fuel tank Size
« Reply #5 on: November 29, 2006, 06:54:05 AM »
Could you cal prevost with the VIN and get the info Faxed?  I did this with Gulfstream with our old Tow behind because the capacities placard with weights was missing.  they have the info for each unit they produce (Each weigh different due to options) by vin.  Maybe this wouold work for you?
FWIW,
Offline niles500
  • Niles500
  • ROSIE
Re: fuel tank Size
« Reply #6 on: November 29, 2006, 08:23:30 AM »
Jaybe - save yourself some time and trouble - Prevost keeps detailed records on their units - call them w/ your VIN# at (418) 883-3391 -while your at it open an account for parts and give them your info for updates, recalls, invites, etc... - HTH
(\__/)
(")_(")
- Niles
Offline eglluvr
  • Jr. Member
Re: fuel tank Size
« Reply #7 on: November 29, 2006, 10:20:21 AM »
 ;D   I like the way you think Niles  ;D
