Author Topic: odor while driving, negative air pressure, venting... SOLUTION???  (Read 12602 times)
Offline viento1
    • my website
If I dare have my window open while someone uses the facilities, the smell is so bad my passengers all try to crawl out the window. I tried fancy vents, simple vents, lil stanker electric vents and I refuse to put nice smelling chemicals in the tank as it smells more like someone $#!% on a x-mass tree.
I believe I have the solution.
Why not install an electric waste valve directly above the holding tank. I could control the switch from the helm and keep it closed while traveling. The toilet would function normally and unless someone is peering down the hole, I do not think anyone would notice. The result would be no sewer gas in the house! The best part is I do not have to buy and maintain a dual flush toilet for $1000.
Thoughts?
Ok, it's time to go on another road trip.
www.randalclark.com
MC5
Re: odor while driving, negative air pressure, venting... SOLUTION???
« Reply #1 on: June 17, 2013, 07:31:21 PM »
There are chemicals that have no odor and are ecologically safe. Every chemical/holding tank toilet I've ever seen uses some sort of chemical to either mask the smell and/or speed up the break down period. Using no chemicals, of course the tank is going to smell like raw sewage-which it is. I use the old fashioned blue powder. While not perfect, it keeps the smell at bay. On warm summer days, just about have to put a packet a day in. I have a 45gal toilet tank. Might try the roof vent with venturi to take advantage of the forward motion to create a vacuum to suck out the smell. Good luck, TomC
Offline viento1
    • my website
« Reply #2 on: June 17, 2013, 08:06:04 PM »
Hey Tom,
Always good to hear from you. I believe my bus creates a zero pressure vortex as I travel through time and space. Maybe more of a giant shop vac. Either way, the tiniest breach in any seal, p-trap, or vent results in a complete transfer of all the sewer gas into the bus.
Even myself, with my lightning fast flushing technique is no match for physics.
www.randalclark.com
MC5
Offline bobofthenorth
    • R.J.(Bob) Evans
« Reply #3 on: June 17, 2013, 08:53:52 PM »
When we run into those aromatic conditions - which isn't all the time but is very unpleasant when it does happen - we open a bedroom window.  That always solves the stink.  I suppose if someone was in the bedroom they might not like that solution but nobody is so its not a problem.
R.J.(Bob) Evans
My website
Contrary to popular belief, wise men do not learn from their own mistakes
They learn from the mistakes of others.
Offline BRUISER
    • iMPAKS
« Reply #4 on: June 18, 2013, 07:56:07 AM »
do you currently have a black tank vent going up and out the roof?
That is what I have and I added those little venturi roof vents and have no issues.
only time i ever had issue was when I was dumping black tank and my son decided to use toilet and let the gas smell from dump station into bus..
iMPAKS.com
Raleigh, NC
1983 MCI MC-9
Offline goutoe
« Reply #5 on: June 18, 2013, 12:11:28 PM »
We were gone last week on a seven day trip, I use the same old blue packets Tom C talks about, about every three days add another packet, then when I was ready to leave I checked out the dump station and there was no way my bus was going to fit so I had to wait to dump till I got home to dump about 150 miles and I had no odor issues I was pleasantly surprised this was the first time I traveled with full holding tanks, so I am a believer in the good old blue chemical FWIW.>>>>>>>>>> John.
John & Linda 1977 AM General 6V92 turbo Detroit 3 Speed allison, 40 ft.
Offline viento1
    • my website
« Reply #6 on: June 18, 2013, 01:21:28 PM »
I know that the magic blue stuff makes poo smell great but I prefer not to mingle my collection of nitrogen and oxygen with  anything my tank has to offer.
www.randalclark.com
MC5
Offline jjrbus
  • MCI5C/N Ft Myers FL
« Reply #7 on: June 18, 2013, 02:55:33 PM »
Stop and think about it.  IF when the window is open(negative pressure) gas is allowed to enter coach. There must be an entrance point (leak)
 The permanent solution is to find the leak, a seemingly impossible task.
 One way is to drain and flush  black and grey tanks, Then seal every opening in the bus.  Go on roof with hose and fill entire system with water, where water leaks gas can leak!
 Second is a smoke test. Smoke sounds complicated but a Google search will help there or ask.
 You can play around and try this and that, but these two methods will almost always find the problem so it can be fixed permanently.
        HTH          JIm
Offline Bill B /bus
« Reply #8 on: June 18, 2013, 03:13:19 PM »
Nothing really complicated as to why the smell enters the bus. According to my teaching the low pressure area at the drivers window (and obviously the door) is the lowest pressure area around the bus except directly behind the bus.
In warm weather we drive with the passenger side bedroom window cracked 6-10". Then we control the amount of air flow by varying the amount of window opening for the driver and co pilot. Sliders in both the driver and door positions. If the toilet is used and "flushed" then odor comes quickly forward as the low pressure by the forward windows is greater than the tank vent on the roof which means all the tank fumes vent into the coach until the valve is shut.
I suppose its fixable but is it worth the effort. If my bladder requires a stop then obviously I've been driving too long.
If in warm weather we ran the AC then it is not problem. We prefer the airflow to control our comfort.
Bill
O
Bill & Lynn
MCI102A3, Series 50 w/HT740
Offline wg4t50
« Reply #9 on: June 18, 2013, 03:46:44 PM »
My simple take; If you do not use chemicals to break down the sludge and control the odor, Then enjoy your mother nature and stop crying while your buddies move away from you.
  ;D
Dave M
MCI7 20+ Yrs
Foretravel w/ISM500
WG4T CW for ever.
Central Virginia
Offline belfert
« Reply #10 on: June 18, 2013, 04:09:36 PM »
I've had serious problems with toilet odor while driving if someone uses the facilities.  I've put in tons of the odor control stuff and it doesn't help even if I put in three times the prescribed amount.  I put on a vent cover that swivels to create a venturi and it helps a lot, but not 100%.
Offline Lin
  • 1965 MC-5a
« Reply #11 on: June 18, 2013, 04:40:43 PM »
We add septic tank bacteria to the tank to help things along.  Another thing is to give air a chance to get into the tank.  The aerobic bacteria is much less noxious.  If by the little blue packets, you mean the stuff that contains formaldehyde, there is a problem with that.  Aside from causing problems for any septic tank you dump in, it is a pollutant. I think using it is banned in California.  If you do use it, the campground can be held responsible for the cleanup.  If they know you did it, they would probably try to come after you.
Offline chessie4905
« Reply #12 on: June 18, 2013, 04:44:45 PM »
  In our coach, we have a ceiling vent/fan combo. with it opened a couple  inches, never had a problem. Could also run fan in "high load" situations.
Offline gus
« Reply #13 on: June 18, 2013, 05:53:41 PM »
If only one air vent is open it causes suction through the path of least resistance, evidently this is the tank vent on your bus.
Always open at least two vents and the problem will go away.
I always open the roof vent if I open the front driver vent.
Or, you can open the bathroom window when you open the front vent.
Offline viento1
    • my website
« Reply #14 on: June 18, 2013, 09:31:13 PM »
I just ordered an electric dump valve and will install it just above the tank. It will stay closed while travelling... Will give full report.
www.randalclark.com
MC5
