June 23, 2018, 09:04:27 PM
Author Topic: Technomadia Update: Catastrophic air filter Failure - Cause or Effect?  (Read 18233 times)
Offline Barn Owl
  • Roanoke, VA
  • PD4106-1063 "Wheezy Bus"
I have used Baldwin air filters (Have a set in the bus now) and from what I have seen their quality is as good as the the other big names. Lots of pleats and sturdy expanded metal inside and out.
Offline belfert
I'm also wondering why Baldwin is considered a poor choice for filters.  I have my oil changed by a bus garage and they use Baldwin oil filters.  My air filters have all been real Donaldson filters because they were the least expensive or I didn't have another choice when I needed one.
You can make your choice about Baldwin-but Detroit already has. If you use a Baldwin oil filter on a DD13, DD15, or DD16 your engine warranty will be void. Why? Because the new Detroits have 50,000mi oil change interval. Two problems-the Baldwin oil filter was found to disintegrate at about 35,000mi and let the engine ingest oil filter element. Also, the oil filter on the DD engines is supposed to have a check valve built into it preventing the oil filter from back flowing down into the oil pan after the engine is shut down keeping the oil filter filled with oil. The Baldwin oil filter did not have the check valve-hence every time you started the engine, the oil filter had to refill up-which meant premature bearing failure and usually a thrown rod.
With the many excellent filters available (I use Donaldson-which happens to be who makes Detroit filters), why would you risk your engine on a Baldwin? My truck came back from Pedco (now Ironman) with Baldwin filters. It now has Donaldson filters. Good luck, TomC
Offline Barn Owl
  • Roanoke, VA
I could only comment on the air filters. They looked good to me.
Offline Barn Owl
  • Roanoke, VA
I am non-apologetically installing K&N filters this week in my bus. I am tired of laying out $100 every time I make a trip up and down my driveway. With the few miles I put on my bus I am not to worried about it. But I think this testing of filters will interest all who are following this topic.
Debunking the K&N Myth – Why OEM is Better
K&N air filter test and review
For decades, the aftermarket hot rod, racing and tuning communities have relied on oiled-media filters to free up that extra few horsepower. In fact, it’s often one of the FIRST modifications many automotive enthusiasts do to their car. K&N filters, to their credit, is generally known to be the top name in oiled filters, and they do a great job of building a quality product. However, it’s always important to evaluate the claims and see exactly what you’re getting for your money.
This report shows, with empirical data and sound reasoning, why OEM filters perform better in a variety of areas.
Special thanks to Arlen Spicer and all others involved in making this information available.
A note from the author:
The reason I started this crusade was that I was seeing people spend a lot of money on aftermarket filters based on the word of a salesperson or based on the misleading, incomplete or outright deceiving information printed on boxes and in sales literature. Gentlemen and Ladies, marketing and the lure of profit is VERY POWERFUL! It is amazing how many people believe that better airflow = more power! Unless you have modifications out the wazoo, a more porous filter will just dirty your oil! Some will say, I have used aftermarket brand X for XXX # years with no problems. The PROBLEM is you spent a chunk of change on a product that not only DID NOT increase your horsepower, but also let in a lot of dirt while doing it! Now how much is a lot? ANY MORE THAN NECESSARY is TOO MUCH!
Others are persuaded by the claims of aftermarket manufacturers that their filters filter dirt “better than any other filter on the market.” Sounds very enticing. To small timers like you and me, spending $1500 to test a filter sounds like a lot. But if you were a filter manufacturer and you believed your filter could filter dirt better than any other media on the market, wouldn’t you want to prove it? Guess what. Test your filter vs. the OE paper. It will cost you $3000 and for that price you will have the data that you can use in your advertisements. Your investment will be returned a thousand fold! EASIER than shooting fish in a barrel! So why don’t these manufacturers do this? Hmmm? Probably not because they would feel guilty about taking more market share.
Now I am not saying that ALL aftermarket filters are useless. A paper filter does not do well if directly wetted or muddy. It may collapse. This is why many off-road filters are foam. It is a compromise between filtering efficiency and protection from a collapsed filter. Now how many of our vehicles collapse their filters from mud and water?
However, if a filter is using “better airflow” as their marketing tool, remember this….Does it flow better? At very high airflow volumes, probably. BUT, our engines CAN’T flow that much air unless super-modified, so what is the point? The stock filter will flow MORE THAN ENOUGH AIR to give you ALL THE HORSEPOWER the engine has to give. And this remains true until the filter is dirty enough to be recognizeable. At that point performance will decline somewhat. Replace the filter and get on with it.
Hopefully the results of this test will do 2 things. Shed some light on the misleading marketing claims of some aftermarket manufacturers and/or give us new insight on products already on the market that are superior to our OE filter.
SCOPE:
This report presents the results of an ISO 5011 test of several air filters designed for the GM Duramax Diesel. The test was independently performed under controlled conditions using a $285,000 machine at Testand Corp of Rhode Island (manufacturer of the machine).
Arlen Spicer, a GM Duramax Diesel owner/enthusiast organized the test. Testand offered to perform the tests at no charge. (These tests typically cost approx $1700.00 per filter). Ken (and employee of Testand), a Diesel enthusiast and owner of a Ford Power Stroke Diesel, shared Arlen’s interest in performing an accurate unbiased test of different types and brands of diesel engine air filters.
The filters used in the test were purchased retail and donated by Arlen and other individual Duramax Diesel owners. The detailed reports from the test have been compiled and are presented in the following pages. The final pages of this report present the behind the test.
ISO 5011 Test:
The ISO 5011 Standard (formerly SAE J726) defines a precise filter test using precision measurements under controlled conditions. Temperature & humidity of the test dust and air used in the test are strictly monitored and controlled. As Arlen learned in attempting his own tests, there are many variables that can adversely affect filter test results. A small temperature change or a small change in humidity can cause the mass of a paper filter to change by several grams.
To obtain an accurate measure of filter efficiency, it’s critical to know the EXACT amount of test dust being fed into the filter during the test. By following the ISO 5011 standard, a filter tested in Germany can be compared directly compared to another filter tested 5 years later in Rhode Island. The ISO 5011 filter test data for each filter is contained in two test reports; Capacity-Efficiency and Flow Restriction.
Capacity and Efficiency:
The Capacity and Efficiency test report presents the test results of feeding an initially clean filter with PTI Course Test Dust (dirt) at a constant rate and airflow. The course test dust has a specific distribution of particle sizes ranging from less than 2.5 microns to greater than 80 microns (see table below).
Every filter is initially tested at 350 CFM and the Initial Restriction or differential pressure across the filter is recorded in IN-H20 (Inches of Water). The filter is then tested by feeding test dust at a nominal rate of 9.8 grams per minute with a constant airflow of 350 CFM. The test is continued until the flow restriction exceeds the Initial Restriction + 10 IN-H20.
At this point the test is terminated and the amount of dust passed through the filter (Accumulative Gain) is measured. Dirt passing through the filter is captured in the Test Station’s Post Filter. The exact amount of dirt passed is determined by measuring the before and after weight of the Post Filter.
Similarly, the amount of dirt retained by the Filter under test – Accumulative Capacity – is measured by taking the difference between the before and after weights of the Filter. From these results the overall % Efficiency of the filter is calculated. This test also indicates how long a Filter will last before replacement is required (or cleaning for reusable filters).
Flow Restriction:
This report presents flow restriction of a clean filter resulting from an increasing airflow. The differential pressure restriction across the filter is reported in inches of water (IN H2O) versus Air Flow in cubic feet per minute CFM.
Data from these reports has been compiled and presented in the following bar graphs, plots and data tables.
Filtering Efficiency:
Filtering efficiency is a measure of the filter’s overall ability to capture dirt.
*Graphic 1*
Accumulative Capacity:
“Accumulative Capacity” is a measure of dirt holding/loading capacity before reaching the maximum restriction limit.
*Graphic 2*
Accumulative Gain:
“Accumulative Gain” is the total amount of dirt that passed through the filter during the test.
*Graphic 3*
(Note: The Purolator was reported to have a seal malfunction during the test and passed more dirt than it would have with a good seal.)
Initial Restriction:
Initial Restriction is the Filter under test’s resistance to flow at 350 CFM.
*Graphic 4*
Dirt Passed Versus Total Test Time:
This graph shows each the duration of each filter’s test versus dirt passed (Accumulative Gain).
*Graphic 5*
In the chart above it’s important to note the different test durations for each filter. The AC Delco filter test ran for 60 minutes before exceeding the restriction limit while the AMSOIL and K&N tests each ran for 20 and 24 minutes respectively before reaching max restriction.
In 60 minutes the AC Filter accumulated 574gms of dirt and passed only 0.4gms. After only 24 minutes the K&N had accumulated 221gms of dirt but passed 7.0gms.
Compared to the AC, the K&N “plugged up” nearly 3 times faster, passed 18 times more dirt and captured 37% less dirt. See the data tables for a complete summary of these comparisons.
Dust Loading:
The dust loading curves show graphically how each filter responded to a constant 9.8 gms/min dust flow before reaching the maximum restriction limit.
*Graphic 6*
K&N filter restriction
It’s interesting to note the shape of these Dust Loading Curves. The AC and Baldwin filters each had near linear responses until reaching maximum restriction. Restriction for these filters increased at a constant rate versus the 9.8 gms/min dust feed rate.
The other filters, most notably the oiled reusable types, had an exponential loading response before reaching maximum restriction. These filters had a lower initial restriction, but they became exponentially more restrictive under a constant flow of dirt.
This runs counter to the “myth” that oiled media filters actually “work better” as they get dirtier.
Also notice the length of the curves as it shows the relative test time for each filter (time to max restriction).
Restriction to Flow:The Restriction to Flow curves graphically show how each “clean” filter responded to a steadily increasing flow of air up to 350 CFM.
*Graphic 7*
The Flow Restriction response curves for each filter have the same basic shape. However, note how the AC Filter, which passed the smallest amount of dirt and had the highest dirt capacity and efficiency, also had the highest relative restriction to flow. The less efficient filters correspondingly had less restriction to flow.
This illustrates the apparent trade-offs between optimizing a filter for dirt capturing ability and maximum airflow.
We hope you’ve enjoyed this article – There’s a lot more Nissan technical articles and useful “how-to” automotive tutorials here – Plus, the friendliest community of car enthusiasts on the web!
Stick around and check out what we have to offer!
« Last Edit: June 21, 2013, 10:32:41 PM by Barn Owl »
Offline Barn Owl
  • Roanoke, VA
Use the blue link, I cannot get the graphics to upload. If anyone else can get it to work it would be helpful for the archives.
Offline Len Silva
    • Leonard Studio
Wow-what a kick in the head.  The filter collapse and the likely failure of the blower seals would explain the oil in the airbox.  I don't know how that would lead to coolant loss without another failure of some kind.
Even if that was all that was wrong, you likely dusted the engine with all that dirt.
It does mean though that you might get it running well enough at a reasonable cost to move it to Bakersfield or wherever.
I'm not one to litigate at the drop of a hat but I would certainly be looking for some relief here.  Continue to document everything.
Offline belfert
A lack of intake air can kill an engine.  Dina buses are notorious for birds building nests in the air intake.  BK knows a charter company running a Dina or two that lost a Series 60 engine due to plugged air intake.  I had a bird nest in mine when I bought it, but it wasn't bad enough to plug the intake totally.  I removed the nest and put hardware cloth over the air intake.
Are Baldwin oil filters really that bad that they shouldn't be used at all on a Series 60?  I just had my oil changed and the shop used Baldwin.  The other shop that normally does my oil changes also uses Baldwin.  I did my own oil change last year and used Fleetguard filters.  (It only costs about $50 labor for oil change so I am going to let a shop do it rather than deal with 10 gallons of used oil.)
What you have to remember-K&N is mostly designed for gasoline engines which don't run at full throttle most of the time. Diesels run at full throttle all the time (no butterfly valve in the intake). You'll notice the K&N has the most dirt ingestion-the Delco paper the least (Donaldson made). For racing engines that only have to run for a few hundred hours then are rebuilt, the K&N is great. On a Diesel that is trying to get thousands of hours of operation, stick with OEM paper element and DON'T blow out the element trying to clean it! Good Luck, TomC
Offline Barn Owl
  • Roanoke, VA
I figured out my late night mistake:
Graphic 1-4
« Last Edit: June 22, 2013, 07:16:20 AM by Barn Owl »
Offline Barn Owl
  • Roanoke, VA
Graphic 5-7
Offline Barn Owl
  • Roanoke, VA
Quote
Not these:
K&N Diesel Air Filters
It is important to point out that the K&N heavy duty air filters are not the ones used in the test above, they were the standard air filters. K&N recommends when using their standard filter in a dirty environment to increase the oil on the filter. Their heavy duty filter line does not use oil.
« Last Edit: June 22, 2013, 07:29:23 AM by Barn Owl »
Offline azdieselman
K&N has a great marketing department! Filters, Not so much.
1980 Mod 10
Online eagle19952
you may say that but I know better.
I have the same K+N  filter in my coach that was in it when I bought it.....I am 44000 miles into it and the previous owner probably had the same...one of my trips was on the Alcan in winter sucking the sand that they use to aid tires on almost every mile. when I got to Beatty, NV I bet I scraped a 1/4 cup of grit from the pre-cleaner area of the filter housing..
And if you read up on their new Hvy Diesel elements....they can be cleaned with a pressure washer....
"A Washable Heavy Duty Air Filter
 K&N has developed a new line of washable commercial grade air filters designed specifically for large turbo diesel engines, class 6-8 over-the-road trucks, agricultural and earth moving equipment, and diesel motorhomes. Built with the unique characteristics of turbo diesel engines in mind, these air filters do not require the use of oil and can be easily cleaned with power sprayers or commercial parts washers. The filters are also designed to provide lower restriction and higher air flow, while delivering exceptional filtration efficiency, and extended service lives...."
Offline azdieselman
Yeah, I should be careful not to bite the hand that feeds. I gets lots of work from them on pickups. Even when I show customers their turbo damage, They won't believe it was the air filter.
1980 Mod 10
