Author Topic: 4106 Radiators - Tips for maximum cooling?  (Read 15084 times)
Offline technomadia
  • Zephyr - 1961 GM PD-4106-446
    • Technomadia
« on: June 26, 2013, 12:16:41 PM »
Our radiator is off at the shop now, and they've just gotten back to us with a quote for re-coring our stock old and beat up 5-core radiator with a new 6-core setup.
I know several people with GM 4106's have mentioned having 7-core radiators (BarnOwl, for one).  The shop here is afraid this might not fit in the space available.
Are there any guidelines or tips I can give them for how to do this optimally for us? Are there any potential fit issues that we will need to work around?
What is the ideal radiator configuration for a GM 4106?
Cheers,
  - Chris
Offline Utahclaimjumper
Re: 4106 Radiators - Tips for maximum cooling?
« Reply #1 on: June 26, 2013, 12:26:04 PM »
 My 06 had the seven core option and it fits with no mods.>>>Dan
Utclmjmpr
 EX 4106 (presently SOB)
Cedar City, Ut.
 72 VW Baja towed
Offline technomadia
    • Technomadia
« Reply #2 on: June 26, 2013, 12:47:12 PM »
Was a seven core radiator an original factory option for the 4106, or is this an upgrade done later?
Offline OneLapper
    • www.markdavia.com
« Reply #3 on: June 26, 2013, 02:32:03 PM »
Upgrade done later.  I don't think 7 core radiators were ever fitted from the factory.
OneLapper
1964 PD4106-2853
www.markdavia.com
« Reply #4 on: June 26, 2013, 02:52:21 PM »
 You must remember that todays radiators are much more efficient than yesteryear, so probably don't need that many cores.>>>Dan  (They are also more delicate and won't tolerate abuse)
Utclmjmpr
Cedar City, Ut.
 72 VW Baja towed
Offline technomadia
    • Technomadia
« Reply #5 on: June 26, 2013, 03:41:20 PM »
For those with seven core radiators, in what ways are the physical dimensions larger than the five core?
  - Chris
Offline Uglydog56
  • I'd rather be lucky than good.
Re: Re: 4106 Radiators - Tips for maximum cooling?
« Reply #6 on: June 26, 2013, 03:59:10 PM »
The part between the tanks where the fins are will be about an inch thicker on the seven relative to the five.
Sent from my SCH-I535 using Tapatalk 2
Rick A. Cone
Silverdale, WA
66 Crowny Crown "The Ark"
Offline skihor
« Reply #7 on: June 26, 2013, 05:07:45 PM »
Serpentine fins and dimpled tubes.
Offline NonHippieBus
« Reply #8 on: June 26, 2013, 07:54:52 PM »
My 4106 got a 7 row core from Macs radiator in Salem, OR about a month ago.  They have bunches of locations in the PNW.
New core bolts to existing upper and lower "tanks" and has identical exterior dimensions.  I overhauled my vernatherm and built a brand now shroud using aluminum and simple hand tools.  I was planning to post some DIY threads on these topics but have been procrastinating
« Reply #9 on: June 26, 2013, 09:05:20 PM »
I'm assuming the radiator core i removed was factory.  It had 4 thick rows clearly visible when the upper and lower "tanks" were removed.
Offline technomadia
    • Technomadia
« Reply #10 on: June 27, 2013, 08:58:23 AM »
My 4106 got a 7 row core from Macs radiator in Salem, OR about a month ago.  ....
I'm confused...  Is it "identical exterior dimensions" or "about an inch thicker" or does this just vary by the radiator shop that does the work?
  - Chris
« Reply #11 on: June 27, 2013, 09:22:23 AM »
Mine is identical external dimensions, more rows in the core.  No exterior dimensional change including core thickness
Offline Uglydog56
« Reply #12 on: June 27, 2013, 05:47:43 PM »
The tanks set the exterior dimensions.  If you look, the finned part is narrower than the tanks. A 7 core is 1 inch less narrower (please pardon my horrible grammar) in the finned part than the 5 core. The thickness of the tanks (depth?) dictates how many cores will fit.
Also another option is a staggered tube setup for more cooling.  Since I'm spending your money and not mine.
Rick A. Cone
Silverdale, WA
Offline RJ
« Reply #13 on: June 28, 2013, 07:14:02 PM »
Chris -
As has been mentioned, the 7 row core will fit using your existing top and bottom tanks.  Number of fins/inch and the dimples improves the heat transfer.
Make sure the torus drive works properly. . . Several may disagree and recommend a straight drive, but if the torus is healthy?
Some folk have replaced the fan with a similar diameter but more blades. . .
Make sure the fan shroud does it's job - no places around it for air to escape.  The fan should suck all the air thru the radiator, nothing from around it.  There have been posts by GM and MCI owners about gaps causing problems. . .
Also, since you tend to stay in warmer climates, freezing is less of an issue.  Therefore, you might consider using a 60/40 or 70/30 water/coolant mix ratio to improve hot weather cooling.  As you probably know, straight water cools the best, but rust becomes an issue quickly!  So you've got to maintain some ratio of coolant to reduce the crud factor.
Just some more trivia for you to ponder!
RJ Long
PD4106-2784 No More
Cheney WA
Offline chessie4905
« Reply #14 on: June 29, 2013, 08:11:59 PM »
  Even though some don't like them, a good mister  system has benefits when you could use some more cooling on a hot day on a long climb. They can be installed at minimal cost after you get your coach back on the road. There are many posts here to help fabricate one with locally available parts.
