Author Topic: Need Part for Old Kohler Generator  (Read 2176 times)
Offline Lin
  • 1965 MC-5a
« on: June 27, 2013, 11:16:07 AM »
The vacuum choke diaphragm on my pre-Columbian L654 Kohler generator is bad.  This is not a huge deal since all it means is that the generator is slower to start in cool weather, or I have to jiggle the choke to start it faster.  However, it would be nice to fix it.  I have not been able to find the diaphragm or a repair kit.  Does anyone know of a source for such ancient parts?
Offline gus
Re: Need Part for Old Kohler Generator
« Reply #1 on: June 27, 2013, 07:57:55 PM »
I had the same problem with my ancient Onan and just choked it by hand until it warmed up.
Not convenient but the part is not available.
Offline Lin
  • 1965 MC-5a
« Reply #2 on: June 27, 2013, 08:49:51 PM »
Yeah Gus, that's what I do when I need to.  Just thought it would be nice to fix it.  Can't understand why they don't have little parts for a merely 40 plus year old generator!
Online luvrbus
« Reply #3 on: June 27, 2013, 09:59:14 PM »
Lin, I have no idea where to get the parts but that has always been a simple fix go to a wrecking and  find a vacuum cylinder off the fresh air door from a automobile find the smallest size, a rod and bracket you are in business you could probably buy one from NAPA or AutoZone
 I watched a guy do that before on a Onan to do away with his electric choke also  it was simple the engine not running the choke was closed running it was open from the vacuum from the engine a old dash pod off a carburetor should work
« Last Edit: June 27, 2013, 10:07:10 PM by luvrbus »
Offline wg4t50
« Reply #4 on: June 28, 2013, 01:59:56 AM »
Years ago I had the Kohler using the flat head 4 cyl water cooled gasoline engine, no diaphragm assist choking, just carb ice under the right conditions, so being a fool, I changed it to LP Gas, had a 60 gal LP tank, worked great as such, my gph went from .75 to 1.1 gph, so I got real tired of that real quick, yes it was a perfectly nice easy, smooth, reliable setup, but LP refills are not cheap and the 60 gal tank gave limited range, so I built the 12 kw diesel, used a 50 gal tank.
I figured 10 gal per 24 hr run, I ran it 24/7, so the 50 gal gave me 4 full days run time.
Dave M
MCI7 20+ Yrs
Foretravel w/ISM500
WG4T CW for ever.
Central Virginia
Offline Paso One
« Reply #5 on: June 28, 2013, 02:00:32 PM »
Okay guys have you tried  www.smokstak.com
Please don't hold me responsible for your extra 3 hours a day you spend on another website. :)
There is a company on there that has NOS parts for all old engines.
Carb kits for many old small engines, broken down by make and model.
68 5303 Fishbowl 40'x102" 6V92 V730 PS, Air shift  4:10 rear axle.
1973 MCI 5 B 8V71 4 speed manual
1996 MCI 102 D3 3129 Cat engine 7 speed manual  and yes I would.
Offline gus
« Reply #6 on: June 28, 2013, 02:28:28 PM »
Better would be an electric, short throw solenoid connected to a switch at the driver. Some of these old engines require a lot of choking.
