Author Topic: I have heat  (Read 1046 times)
Offline somewhereinusa
    • somewhereinUSA
I have heat
« on: June 29, 2013, 07:51:26 AM »
I have finally got the Espar Hydronic10 boiler going and now have domestic hot water and the first loop  of heat that goes to the front and the original heater core with an added core for driver feet.
Temperature drop in entire loop is only 4 degrees with outside temp at about 70.  Temp coming out of boiler is about 106. Does anyone know what the outlet temp should be?  The only reference I can find is that overtemp shut down is 115, but no reference as to what operating temp should be.
Dick
1991 Bluebird AARE
1999 Ford Ranger
Andrews,IN
Re: I have heat
« Reply #1 on: June 29, 2013, 08:13:26 AM »
On the 12 the shut is @ 235 F degrees (115 C) the operating range with the standard switch is 158- 176 degrees F the hotter switch is 178-198 degrees F I would think the 10 and 12 should have the same temperature range maybe not
« Last Edit: June 29, 2013, 08:23:14 AM by luvrbus »
Offline B_K
Re: I have heat
« Reply #2 on: June 29, 2013, 08:35:20 AM »
Great!
But I think it's the wrong time of year for heat unless your a reptile!
Offline Purplewillie
Re: I have heat
« Reply #3 on: June 29, 2013, 08:48:01 AM »
Great!
Lol. That's what I was thinking BK
We are on the start of a record breaking heat wave
Mark
Mark & Char
1976 P8M4905a 8v71 v730
British Columbia Canada
Offline Lee Bradley
Re: I have heat
« Reply #4 on: June 29, 2013, 10:03:54 AM »
Of course it works now, its when you need a system it fails.  Murphy #8
    • somewhereinUSA
Re: I have heat
« Reply #5 on: June 29, 2013, 10:25:58 AM »
Quote
I may very well be, I tend to not do much when I'm cold. I figure now's the time to work on it while I'm still mobile.
I finally found the temps for the 10 If I'm reading it right the unit cycles down at 162, if it gets to 185 it shuts down, then restarts at 145.
I'm not getting anywhere near that.  I'm not too sure of my readings. I'm using a infrared non contact tester that seem fairly accurate. I'm measuring the temp of the pex about 8 inches from the boiler and it cycles between 125 and 115, which to me is a bit on the cool side. I have also noticed that if i measure the temp at any of the brass fittings it measures about 8 degrees cooler than the pex line.  Why is that?
1991 Bluebird AARE
1999 Ford Ranger
Andrews,IN
Offline niles500
  • Niles500
  • ROSIE
Re: I have heat
« Reply #6 on: June 29, 2013, 12:57:58 PM »
Somewhere - the difference in temp between Pex and Brass is the different emissivity of metals - put a piece of electrical tape on the Brass and then shoot the temp - HTH
P.S. Is there not an adjustable thermostat on the unit?
(\__/)
(")_(")
- Niles
Offline lorna
Re: I have heat
« Reply #7 on: June 29, 2013, 02:44:18 PM »
Quote
"I have heat"
They make a nice soothing powder for that.
