Author Topic: Rv sofa without sleeper  (Read 1042 times)
Offline Busnut83
« on: June 29, 2013, 01:13:39 PM »
I need 2 sofas 68in with out the sleeper?  Does anyone make them.  I surf the web and i have not found a company?????  Must also fit thru prevost door 24 in.
Offline muldoonman
  • 1991 Prevost 8V92TA
Re: Rv sofa without sleeper
« Reply #1 on: June 29, 2013, 02:29:31 PM »
Hope you find something. You could always do what they did on my full size double door fridge/freezer. Pull the passenger window out of my prevost. Not for the faint of heart.
« Reply #2 on: June 29, 2013, 05:26:31 PM »
Google RV sofa. Flexsteel makes them, and usually come apart so you can get it in the door. Make sure to get one with the drawer underneath. Good Luck, TomC
Offline Ed Hackenbruch
« Reply #3 on: June 29, 2013, 05:39:38 PM »
 We got a Flexsteel sleeper sofa that is 72L x 31D x 36H thru the door of my 5A which is only about 28-29 inches wide. I can't remember if we had to take off the arms or not,......but we did remove the co-pilot seat and i think there was some cussing involved.   ;D
Used to own a 1968 MCI 5A with 8V71 and Allison MT644 transmission.
Offline Gerry H
  • 1992 Prevost LeMirage XL-40 8V92 740 Allison
« Reply #4 on: June 29, 2013, 07:35:13 PM »
Just bought an 83" Villa sleeper with Flex Steel air mattress from Bradd & Hall Elkhart IN. It will go through our openable Prevost window, like the fridge did. Villa will make you anything you want (at a cost) Flexsteel makes limited types and comes in second in my opinion, and then there's all the rest. Custom building and upholstery seems like the way to go, if you can find someone that does it. Then cross your fingers on the outcome. Good Luck Gerry H
Forest Lake, Minnesota
Land of 10,000 mosquitoes and a few cool buses
Offline Seangie
  • www.herdofturtles.org
    • Herd of Turtles
Re: Re: Rv sofa without sleeper
« Reply #5 on: June 29, 2013, 08:43:45 PM »
We got our furniture at http://www.discountvantruck.com/ and are happy with it.
They make all of their own furniture and I am sure they could do a custom sofa for you.  There is a pic posted on our website here -http://www.herdofturtles.org/2013/06/28/setting-up-shell/
Not a great pic.  I posted some pics a while back as well if you search my previous posts.  Just one option of many that are out there!  Best of luck!
BTW -  the dual recliner is 68"  with the middle piece.  Doesn't turn into a bed and the recliners go almost flat.  There is less than 24" between the front of the recliners and the bench seat across from it.
1984 Eagle Model 10S
'Cause you know we,
Driving through the night
To that old promised land'
