Author Topic: 240 volt roof air  (Read 7006 times)
Offline bevans6
  • 1980 MCI MC-5C
Re: 240 volt roof air
« Reply #15 on: July 05, 2013, 06:40:21 AM »
Volts and amps are the two sides of a teeter totter.  Watts are the pivot point in the middle.
Offline TedCalvert
« Reply #16 on: July 05, 2013, 07:05:58 AM »
I've been a wire-wiggler for a long time and have often struggled to give an analogy of Volts X Amps = Watts to my wrenching friends.  (let's not go into power factor!). Your explanation is great!  May I use it?
I've finally figured out that torque X rpm = horsepower. Sort of. So then a gear reducer is a transformer.
Ted
Offline bevans6
  • 1980 MCI MC-5C
« Reply #17 on: July 05, 2013, 07:29:11 AM »
By all means use it.  I am surely not the first to think of it, but it just came to me when reading this thread.
Offline Lin
  • 1965 MC-5a
« Reply #18 on: July 05, 2013, 08:56:17 AM »
In any case,  now that the electrical miracle is ruled out,  there is no benefit to using a 240 rooftop.  It will only complicate life.  We used to run an AC on a 3500 w. A good 3000 may do it too,  but it is good to have a bit of reserve.
Offline Seangie
  • www.herdofturtles.org
    • Herd of Turtles
Re: Re: 240 volt roof air
« Reply #19 on: July 05, 2013, 04:20:34 PM »
Scott -  don't do it.  I've got 240v AC and already we are feeling the complications/limitations of using 240v.  Add to the fact that its 50hz and your just complicating things.
It would be one thing if it was a super pizazzical AC unit that cooled the entire coach with exuberant features but if its just saving a few bucks to use something that's available it might be more trouble than its worth.
1984 Eagle Model 10S
'Cause you know we,
Driving through the night
To that old promised land'
Offline Lin
  • 1965 MC-5a
« Reply #20 on: July 06, 2013, 09:02:45 AM »
Just a note here, if you are looking to use a small generator, the Honda 2000's can be put in tandem, so you can use one or both depending on your needs.  There would certainly be enough power for one AC with both, while using only one for smaller things like charging batteries.
Offline Scott & Heather
  • MCI-9 & MCI-102
    • Fresh Day Music
« Reply #21 on: July 06, 2013, 08:17:15 PM »
Thank you so much for the explanations. Love reading every one of your responses. Love the teeter totter example. Ok, so now that I've figure that out, I won't consider a 240 volt model. Sean confirmed by personal experience that it can be a pain.
Sent from iPhone via Tapatalk
