June 23, 2018, 03:10:05 PM
Author Topic: Marker Clearance lights  (Read 1326 times)
Offline Tikvah
    • Dave & Amy
« on: July 04, 2013, 11:16:27 PM »
Some confusion
Are Marker lights and clearance lights the same?
My MC-9 book says stud 15 16 front, but the electrical door sticker says those studs are reading lights.  15 16 have a plate connecting them together.
The book also says stud 3 in the rear.  Where do they divide?
 Are some fed from the rear and some from the front?
My rear clearance are still hooked up, but I've removed all the other wire and its time to rewire.
Any help would be appreciated.
Sent from my DROID RAZR HD using Tapatalk 2
1989 MCI-102 A3
DD 6V92 Turbo, Alison
Tons of stuff to learn!
http://dave-amy.com/
Offline Jriddle
Re: Marker Clearance lights
« Reply #1 on: July 05, 2013, 01:09:34 AM »
Yes they are the same. The middle and front are feed from the from front box. Then rear are feed separate from the front.
If It Can't Be Grown Then It Has To Be Mined
John Riddle
Wells NV
1984 MC9
Offline RJ
« Reply #2 on: July 05, 2013, 05:50:46 AM »
The three lamps in the center front & rear are often referred to as "Michigan Markers."
The lamps on the upper corners of the chassis are usually known as clearance lamps.
90% of folk use the terms interchangeably.
Your choice.
RJ Long
PD4106-2784 No More
S13406 1978 MC-5C Converted
6V71/MT-644
S14947 1980 MC-5C Shell
6V92/HT-740
Cheney WA
Offline belfert
« Reply #3 on: July 05, 2013, 12:18:17 PM »
Is it common to have five of the "Michigan Markers" front and rear?  I also have side clearance lights at the front and rear too so I have seven lights on the front top and back top of the bus.  My "Michigan Markers" are Grote lights commonly used on school buses.  I have replaced most of them with new Grote LED lights as the originals are all corroded inside.
(I did find that one of my LED side clearance lights barely lights up even though it is fed by the same wire as one of the "Michigan Markers".  Another thing to fix.)
Offline Mex-Busnut
« Reply #4 on: July 05, 2013, 01:16:26 PM »
Check your ground connection for that light.
Jake brakes
Offline belfert
« Reply #5 on: July 05, 2013, 01:52:56 PM »
The ground is hardwired to the same ground as the other marker light on the circuit.  It is not grounded through metal contact.  It is something I will check.  I'll probably pull the light off and see if it works directly off a 12 volt battery.
