Author Topic: Item needed  (Read 3396 times)
Offline tuccitown
  • Jr. Member
Item needed
« on: July 18, 2013, 03:36:14 PM »
Anybody know where I can get the intake hose for my coach (see attached) locally to Seattle? Does anyone have a part number? This is the intake hose from silencer to oil bathed air cleaner.
Thanks in advance,
Jack
1979 GMC H8H649-053 Conversion in progress.
1955 GM PD 4501-377 Converted.
Online luvrbus
Re: Item needed
« Reply #1 on: July 18, 2013, 04:04:03 PM »
That is called hump hose just measure the ID and length you probably have to order it that one looks like 7 in id Napa if you get the right parts guy can have it overnight fwiw 1 hump will work for you just as good as the 4 you have
« Last Edit: July 18, 2013, 04:09:38 PM by luvrbus »
Offline Scott & Heather
  • MCI-9 & MCI-102
    • Fresh Day Music
Re: Item needed
« Reply #2 on: July 18, 2013, 04:24:18 PM »
Hey Cliff, you sure it's called a hump hose? Maybe you made that up just like slobber tube :) ;)
Sent from iPhone via Tapatalk
Online luvrbus
Re: Item needed
« Reply #3 on: July 18, 2013, 04:30:34 PM »
nope didn't make it up www.intakehoses.com and others
Offline Gordie Allen
    • THIS OLD BUS
Re: Item needed
« Reply #4 on: July 19, 2013, 04:46:28 PM »
Augusta, MI
1956 4104
DD 671
Online luvrbus
Re: Item needed
« Reply #5 on: July 19, 2013, 04:54:10 PM »
Only bad thing about silicone hump hose the least bit of oil will destroy it, the stuff is expensive and not compatible with oil found that out the hard way
    • THIS OLD BUS
Re: Item needed
« Reply #6 on: July 19, 2013, 04:57:19 PM »
True.  Didn't think about outside contamination, or oil bath fumes.
Augusta, MI
1956 4104
DD 671
Offline tuccitown
  • Jr. Member
Re: Item needed
« Reply #7 on: July 23, 2013, 11:07:33 AM »
Thanks, I ended up ordering one of these as Napa was not much help.
http://intakehoses.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=55H55&Category_Code=HH1
Didn't realize they were in Washington so hopefully I'll get it pretty quickly.
Thanks again.
Jack
