Author Topic: 1966 GMC Buffalo PD4107  (Read 6034 times)
Offline blujon
« on: July 31, 2013, 03:52:09 PM »
I posted before and have given some wrong info, the bus my brother has is the 1966 GMC Buffalo PD4107, and would greatly appreciate it if someone would put him in touch with a mechanic to discuss difficulties with his bus. His name is Jim, and he can be reached at 347 545 0812. Even it is possible to change the bus from a stick to an automatic transmission!
Thanks, John
Offline RJ
Re: 1966 GMC Buffalo PD4107
« Reply #1 on: July 31, 2013, 07:21:19 PM »
I talked to Jim on the phone this evening.  Bus belonged to his son, who sadly passed away from a heart attack recently.
Coach is located in an RV storage about 10 - 15 mi south of Charlotte, NC off I-77 at Exit 90.  Says it's on the grounds of the old Jim & Tammy Bakker Heritage USA property.
Jim needs someone familiar with GMC buses to meet him there, probably in September (he's in FL right now), to adjust the clutch properly after a "mechanic" did and made it worse.  Says reverse solenoid works, but won't pull it into gear after the "adjustment."  He can get it into reverse using the old broom handle trick.
Coach is fully converted, Jim says his son would often spend weekends using the bus.
After he gets the clutch issue resolved, the bus will be for sale at a very reasonable price, as none of the other family members are interested.
Jim is also "electronically-challenged", so will need help from fellow busnuts taking/posting pics to help sell the rig.  He doesn't own a computer, so using this medium is foreign to him, thus the help request.  (There are no pics available at this time.)
So, who's in the Charlotte, NC area?  Uncle Ned??  Gene Russell??  Anybody else in that neck of the woods that could help?
Thanks, guys!
FWIW. . .
RJ Long
PD4106-2784 No More
Cheney WA
Offline pvcces
« Reply #2 on: August 02, 2013, 10:38:05 PM »
If he just wants to sell it, changing to an automatic does not make much sense to me.
I wish him good luck.
Tom Caffrey
Tom Caffrey PD4106-2576
Suncatcher
Ketchikan, Alaska
Offline B_K
« Reply #3 on: August 03, 2013, 04:07:04 AM »
JR used to be from the Charlotte area.
But I've not seen or heard anything from him on here in ages!
Offline RJ
« Reply #4 on: August 03, 2013, 08:52:07 AM »
Tom -
Jim told me on the phone he now just wants to get the manual transmission/clutch issue resolved and then he'll sell it.
Makes the most sense, considering his situation.
RJ Long
PD4106-2784 No More
Cheney WA
Offline chessie4905
« Reply #5 on: August 03, 2013, 11:17:25 AM »
 Many times the reverse issue is from removing the slop on the reverse solenoid linkage. You need to remove the end cap and look at the contact points. They should open when solenoid reaches it's full travel to disconnect solenoid pull windings. You also want to inspect points for excessive deteoriation/burning. You adjust the linkage on the solenoid arm to achieve this. When right, the linkage looks sloppy loose. You remove all the slop and you'll have solenoid issues. It explains adjustment in manual.
« Last Edit: August 03, 2013, 11:19:11 AM by chessie4905 »
Offline pvcces
« Reply #6 on: August 05, 2013, 09:53:03 PM »
RJ, I agree.
Tom Caffrey, still lookin'.
Suncatcher
Ketchikan, Alaska
Offline DMoedave
« Reply #7 on: August 08, 2013, 08:19:47 AM »
I called Jim a little while ago to put him in touch with a mechanic in Durham area, not close but at least someone who knows buses. In talking to Jim, its not a clutch issue, she goes in gears fine and is drivable, just wont go into reverse. he took off the reverse solonoid and had it tested at an altenator shop who said it was good.
I think if a local busnut could get there they could figure it out pretty easy. Hard part is Jim is in Fla, bus is in Charlotte area, and ex wife of Jim is in charge of bus. Someone is coming to look at it this weekend and they just want to get the bus sold. I recommended getting pictures and specs on the bus classifieds here and at Busnut.com They are wanting to sell it for 10K. Anyone interested in looking at bus or helping out should call Jim at the number listed. Thanks, dave
we love our buses!!! NE Pa or LI NY, or somewhere in between!
Offline uncle ned
    • Visit: Busconversionstuff.com
« Reply #8 on: August 08, 2013, 08:30:09 AM »
The person I would call is Davids coach at  828 874 6105.
He located in Connelly Springs NC.Bear sent you then he will charge you twice as much
He is a super guy and great detroit and bus person.
Just tell him Ned owner of Huggy Bear then he will charge you twice as much.LOL LOL
uncle ned
4104's forever
6v92 v730
Huggy Bear
Offline chessie4905
« Reply #9 on: August 08, 2013, 08:46:07 AM »
   That solenoid plunger has to move 3/8 inch or slightly more before it takes up slack to start moving reverse lever. No slack and it won't work. Less than 3/8 inch slack will cause problems when transmission has warmed up. Doing the point adjustment is best way to have it correct and reliable, although just making the slack adjustment will probably help. In case if the adjustments are right, it could be low voltage to the solenoid.  check with a voltmeter or a proper voltage supply hotwire
