Author Topic: MC9 Parking Brake Leaking Down While Running  (Read 13332 times)
Offline bevans6
  • 1980 MCI MC-5C
Re: MC9 Parking Brake Leaking Down While Running
« Reply #30 on: August 21, 2013, 02:53:59 PM »
Yes. I would use a 1" ratchet strap.  It's just so you can open the middle clamp ( where the spring is) and kind of ease it open rather than chase parts around the parking lot.  You can compress the spring by hand easily, but the strap is kind of a third hand.
Offline Cary and Don
« Reply #31 on: August 21, 2013, 03:14:58 PM »
Once you have them open,  clean the interior of the chambers and smooth any rough surface.  Getting everything really smooth makes all the difference in them not leaking after you put them back together.  We broke a couple of the bolts that hold the the clamp rings on.  You might want to pick up a couple before starting.
Don and Cary
1973 05 Eagle
Neoplan AN340
Offline Cecil The Diesel
  • Vagabond Dreamer, Rhymer And Singer Of Songs
    • Peewee Moore
« Reply #32 on: August 26, 2013, 11:29:08 AM »
Had a hole in one of the diaphragms, and then... I had a severe leak in one of the copper supply lines to the relay valve. The cans were very clean inside though and I was real happy with that. I had to cancel 5 shows in a row but the "Dixie Cannonball" is back up to full pressure and on the road again. Next stop Shawnee OK, Memphis TN, Jackson TN, and Cookeville TN.
Thanks for all the helpful advice. I don't know what I would do without this community!
1982 MCI MC-9 8V71 5 Speed
Support Independent Outlaw Country
www.peeweemoore.com
Offline B_K
« Reply #33 on: August 26, 2013, 01:08:32 PM »
Glad to hear ya have it fixed.
If ya have any troubles between Memphis and Cookeville give me a shout!
I'm about 45 mins from Jackson 15 miles N. of exit 108!
