BCM Community
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
BCM Home
Forum
Help
Forum Rules
Search
Login
Register
BCM Community
Bus Discussion
(Moderator:
Getting under the bus
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Getting under the bus (Read 2442 times)
Danny
Sr. Member
87' MCI 102A3 - getting there...
on:
December 05, 2006, 07:44:27 AM »
After reading the post regarding draining the air tanks I got thinking about actually getting under the bus. I have never done that. I have a friend who while working on something the air started going down while he was under the bus. He said it was an interesting experience. What is the answer? Blocks, digging a trench down the middle under the bus,
What are the thoughts of the group?
Thanks (as always)
Danny
Logged
I have heard it said, "life comes at you fast". I didn't know it would be in the shape of a bus :-)
H3Jim
Hero Member
1995 Prevost H3-41, series 60, B500 Allison
Re: Getting under the bus
Reply #1 on:
December 05, 2006, 08:03:33 AM »
Safety is the main concern. There are several ways to ensure that the bus won't come down on you. Trench, pit, blocks, ramps, park on a slope. Avoid getting under there at all and pay someone else to do it. The main idea is that stuff happens, and if the bus comes donw on you, you will likely be dead, so make sure you don't put yourself in that position. Air bags can deflate, even if you've never seen them do it. Jacks can slip or be driven into pavement due to the seer wieght of the bus. Its all been said before, some if it is just common sense. I personally have ramps, and for other stuff I take it to the dealer who puts it up on a lift.
Logged
Jim Stewart
El Cajon, Ca. (San Diego area)
Travel is more than the seeing of sights, it is a change that goes on, deep and permanent, in the ideas of living.
Hero Member
Reply #2 on:
December 05, 2006, 10:01:32 AM »
Hello Danny.
You may get yourself a couple of pieces of hardwood the right size to slip into the 4 points on the coach where the bump stops are at the front and rear axles. (none at the tag) You can do this by reaching around the tire.
That will block the suspension.
Still have to wonder about a tire deflating....
A set of ramps are quite handy to get yourself some more clearance for crawling around.
Again good quality lumber, layered 2 x ? fastened together somehow have been reported to work well.
Taking advantage of the geography, finding dips or drop-offs that the bus may safely approach.
I might suggest that it is pretty hard to properly maintain the coach without getting under it periodically to lubricate everything, check the brakes, inspect for deterioration and structural cracking, find the sources of air leaks and repair/replace the offending component.
Until she allows me to build a pit... once a year, (my mileage is low) I jack it up, remove the wheels, railway tie under the axle, block in the suspension, and crawl around through the large opening and grease and inspect it all. After the pit, I'll still pull the wheels annually, so they will acually come off when I need them to at the side of the road somewhere...
Logged
Buffalo SpaceShip
Hero Member
Reply #3 on:
December 05, 2006, 11:11:34 AM »
Here's a project page I made a long time ago for some quick and simple run-up blocks:
http://www.thefamilybus.net/projects/blocks/
I have another set that is 4 boards high (4 x 1.5" = 6"). There's no doubt a million ways of building these, and this is just one way. Mine are very portable and I never leave home without 'em.
HTH,
Brian B.
Logged
Brian Brown
4108-216 w/ V730
Longmont, CO
H3Jim
Hero Member
Reply #4 on:
December 05, 2006, 11:43:06 AM »
And to drive the bus onto the ramps or runup blocks here is an easy wasy to dirve jsut the right amount if you are by yourself. measure the distance that you want to move forward, centerline of the wheel where it is, to the location where you want to be parked. Put a step ladder that same distance in front of your bumper. drive forward unti you just hit the ladder.
I have found that with the large tires and low first gear, I can hardly tell when I've driven up a 7" ramp, so this method gets me placed in just the right spot eveytime. Even a 4 x 4 stop block is not enough to stop teh bus, or even tell when I've reached it.
Logged
Jim Stewart
Print
Pages: [
1
Go Up
« previous
next »
BCM Community
Bus Discussion
(Moderator:
