June 24, 2018, 12:54:00 PM
Author Topic: Which End?? 8v-71  (Read 5828 times)
Online luvrbus
Re: Which End?? 8v-71
« Reply #15 on: August 24, 2013, 04:22:54 AM »
Most marine engines the lefty will have the starter mounted on the right side looking from the rear just like your GM  then there is always the model number on the block if all else fails  ;D
As I said nothing changes rotation except the crank the blower,fuel pump,water pump and any other accessory turn the same direction on right or left handed engines
« Last Edit: August 24, 2013, 04:32:18 AM by luvrbus »
« Reply #16 on: August 25, 2013, 08:45:32 AM »
And will have to change the oil pump if the oil pump is mounted on the front of the crank. Good Luck, TomC
