Author Topic: Windshield motor pump for GM 4104  (Read 6926 times)
Offline harleyman_1000
    • My bus
« on: August 23, 2013, 07:20:50 PM »
 Does anyone have a windshield motor pump for a GM 4104?
Scott
St.Louis Missouri
Offline gus
Re: Windshield motor pump for GM 4104
« Reply #1 on: August 23, 2013, 07:29:42 PM »
There is no pump, it runs off the air system.
    • My bus
« Reply #2 on: August 23, 2013, 07:47:08 PM »
Ok, what is it called? A regulator? My drivers side one doesn't work the air inlet cracked and broke
Scott
St.Louis Missouri
Offline bevans6
  • 1980 MCI MC-5C
« Reply #3 on: August 24, 2013, 02:52:21 AM »
Do you mean the bit that flaps the wiper back and forth?  It's the windshield wiper motor.  You could also mean the windshield wiper control, on the dash, that regulates the air flow to the motor.  If you mean a pump, you could mean the air pump thingy that is inside the washer bottle that holds the fluid.  It has an air regulator control on the dash too.  So you could mean about 6 different things...  They all run off air pressure.
    • My bus
« Reply #4 on: August 24, 2013, 08:34:27 AM »
 I mean  "the bit that flaps the wiper back and forth?  It's the windshield wiper motor."    :-[  My bus doesn't have windshield fluid shooter outter thingy....lol
Scott
St.Louis Missouri
« Reply #5 on: August 24, 2013, 08:37:50 AM »
If you just broke the air line connection you can buy those without buying the complete motor fwiw
Offline treeplanter
  • the grey ghost,1971 GMC 5305A
« Reply #6 on: August 24, 2013, 08:47:03 AM »
Luke at U S Coach has many of the parts you will need to fix your bus.
Timothy
Offline Len Silva
    • Leonard Studio
« Reply #7 on: August 24, 2013, 08:49:26 AM »
There were two different motors and controls used on the 4104, Trico and Sprague.  I think the Sprague was for the pantograph wipers and Trico for the standard, but I'm not sure.
Offline treeplanter
« Reply #8 on: August 24, 2013, 08:55:18 AM »
Mine are Air Push rebuilt them and still don't work, next replace the control valve$.
Timothy
« Reply #9 on: August 24, 2013, 09:01:04 AM »
Air Push is a trade name for Sprague same motor
Offline gus
« Reply #10 on: August 24, 2013, 11:12:56 AM »
Make double sure it isn't the switch/regulator.
Those things failing have caused a lot of motors to be replaced!
I repaired one but don't remember how I did it, just that it wasn't very easy.
Next time I'll just substitute a plain ole air valve and be done with it. The plumbing is a real PIA and has oddball fittings.
    • My bus
« Reply #11 on: August 24, 2013, 04:01:36 PM »
 Mine says "Air Push" on it. It wasn't the air line that broke, but the plate with the threads in it that the line screws into that broke. Im trying to upload pictures from my phone that shows it, but having trouble.
Scott
St.Louis Missouri
    • My bus
Scott
St.Louis Missouri
    • My bus
« Reply #13 on: August 24, 2013, 04:32:36 PM »
 That link is to my windshield motor picture. I couldn't get it to upload here? It is a blurry picture, but it you look closely to a copper line just to the left of the yellow line. you will see what broke.
Scott
St.Louis Missouri
Offline tekebird
« Reply #14 on: August 24, 2013, 07:21:45 PM »
did the fitting on the motor break?
