Author Topic: mci throwing belts  (Read 7837 times)
Offline christopher
mci throwing belts
« on: August 30, 2013, 05:42:14 PM »
what causes the belts to flip or come off the pulleys?
Chris
MCI5C
Re: mci throwing belts
« Reply #1 on: August 30, 2013, 05:49:31 PM »
Check the belt adjuster if it has a pneumatic adjuster be sure the valve is on
Offline lostagain
  • MC5C
« Reply #2 on: August 30, 2013, 05:55:02 PM »
The belt has to be the right size for the pulleys: the angle has to match the pulley's, and more importantly, the belt has to ride in the pulley without touching the bottom. Look and make sure the belt does not ride against the bottom of the V in the pulley. The belt has to ride on the sides of the V, off the bottom. If it does, get a bigger belt. A belt the right size for the pulleys will last a long time, and will also tolerate some misalignment.
JC
JC
Blackie AB
1977 MC5C, 6V92/HT740
« Reply #3 on: August 30, 2013, 06:05:16 PM »
To add to JC comments be sure it is a automotive belt not a hardware store belt for some type motor to run equipment big difference in the 2 type belts once a belt flips correct the cause then you buy new belts very seldom can you make it stay on after it flips
Offline kyle4501
  • NEWELL in South Carolina
« Reply #4 on: August 30, 2013, 06:11:53 PM »
Some other thoughts -
Is it a new belt or an old one? If old, it may have some broken cords & needs replacing. If new, then check pulley wear & alignment. Also confirm the idler pulley bearings are in good condition.
« Reply #5 on: August 30, 2013, 06:21:44 PM »
Wonder which belts he is throwing the alternator or blower ?
Offline B_K
« Reply #6 on: August 30, 2013, 08:26:21 PM »
I've also seen belts flip or come off if the engine cradle somehow loosens up and the whole thing moves causing misalignment. (not something that happens everyday, but I've seen it on several coaches over the yrs!)
Offline wg4t50
« Reply #7 on: August 31, 2013, 03:05:41 AM »
All the above, howsomever, the only belts that consistantly flip over are the Dayco brand, between fliping over or breaking, the Dayco belts have never been a success story for anything I have tried them on.  Instead never have had an issue with the  Gates brand, same as NAPA brand.
I never had an issue with my origional belt setup on the MC7, so am wondering about alignment and tension ?
Never heard a word about this on a MCI, should be a simple fix, I'm guessing on that.
MCI7 20+ Yrs
Foretravel w/ISM500
WG4T CW for ever.
Central Virginia
Re: mci throwing beltst
« Reply #8 on: August 31, 2013, 06:09:55 AM »
I have had good luck with the Goodyear belts over the years,I bought a belt from a mill supply one time in Conroe Tx when I lost a blower belt on the 8 it was 1/2 the cost I had paid before and it was worth every penny I could not keep it on the belt was still in the bay when we sold the bus
Offline eagle19952
« Reply #9 on: August 31, 2013, 07:25:58 AM »
this helped immensely when I had this same problem....the tool.
you might even find mis-matched pulleys....
Brent from Gates Product Applications demonstrates how to use a V-belt sheave gauge, a maintenance tool which determines if a belt fits properly in its sheave groove. Learn how to select the proper gauge size for different belt cross sections and how to identify unknown belt cross sections. Contact Gates Product Application with any questions (303)-744-5800 Opt 2.
V-Belt Sheave Gauge - Gates Corporation
« Reply #10 on: August 31, 2013, 07:58:12 AM »
Yea you can buy those gauges for 5 bucks a set some parts houses will give you a set along with a belt tension gauge
Offline HB of CJ
Excellent Answers Already Given
« Reply #11 on: August 31, 2013, 02:59:19 PM »
Reasons why belts jump off?  1) Wrong size belt. 2) Not specific belt.  3) Wrong grade belt.  4) Worn belt.  5) Loose belt.  6) Over tight belt. (sometimes) 7) Tight but non aligned pulleys. 8) Loose non aligned pulleys.  9) Worn out tensioner.  10) Sudden RPM shift.  11) Road debris in pulley,  12) Wet belt. 13) Hot belt. 14) Frozen cold belt.  15) Belt vibration caused by bad engineering. 16) Overloaded belt. Wow!!  HB of CJ (old coot)
Offline christopher
« Reply #12 on: August 31, 2013, 07:05:11 PM »
Thanks for all the replies. My bus has tossed the ac belts and blower belts. Ill do some checking and see what the deal is. I have a feeling its mialignment.
Chris
MCI5C
Offline eagle19952
« Reply #13 on: August 31, 2013, 07:34:31 PM »
Chris
MCI5C
so did I..... it was worn and mismatched pulleys....
ask yourself how would the pulleys get mis-aligned ?
bad bearings...
re-engineered by any other means except FACTORY design....
when did it start...
mine started very soon after I got my coach....turns out someone replaced the fan/alt drive with one not the same as 1979 oem. that one pulley was worn more than all the rest because it got worn out on a different coach....
Offline bevans6
  • 1980 MCI MC-5C
« Reply #14 on: September 01, 2013, 02:57:18 PM »
I would check the obvious - that the crank pulley isn't coming off, that the blower gearbox and AC compressor cranks are good and their pulleys aren't coming off.  If one belt came off it could take the others with it.  I seem to recall the blower drive belt on the MC-5C is an MCI only part, I got one from Luke.  I couldn't get one from my local jobber.
