June 24, 2018, 05:42:52 PM
Author Topic: Bus Mechanic in Spokane/Post Falls  (Read 3156 times)
Offline Doug1968
« on: September 03, 2013, 08:34:37 PM »
Fellows,
Does anyone know of a good shop/mechanic in the Spokane/Post Falls area. Looking for someone that can troubleshoot and resolve an overcharging problem on a MCI 9.
Also looking for a service and fuel filter change and a good source for tires.
I would appreciate help in locating a good shop.
Doug
1986 MCI 102A3 - 8V92 - 5 speed
Vancouver, Washington
Offline pvcces
Re: Bus Mechanic in Spokane/Post Falls
« Reply #1 on: September 03, 2013, 10:37:08 PM »
Doug, while troubleshooting your symptom, remember that a voltage regulator has to be connected to a positive wire and a negative, so a loss of ground can cause overcharging. This is often overlooked.
Be sure to measure the voltage input to the regulator. If it is high and still charging, that should be a defective regulator. If it is low, you have a circuit failure.
Good luck.
Tom Caffrey
Tom Caffrey PD4106-2576
Suncatcher
Ketchikan, Alaska
Offline Don4107
« Reply #2 on: September 03, 2013, 10:51:39 PM »
I would be interested too since I am just South of Spokane.
The only local shop I have had contact with was:
Alpha Omega Diesel & Bus Repair
6624 N Freya St Spokane, WA 99217
(509) 468-8068
I have not had them do any work but they loaned me some brake parts to get me rolling until I could replace them from Luke.  Very nice people.  They maintain their own charter fleet and some of it has some age.  Don't know if they are 2 cycle savvy.  The person I dealt with did not have much gray hair. :)
I have been meaning to stop by Spokane Transit to see if their is some gray hair there or someone they recommend.
Good luck.
Don
Don 4107 Eastern Washington
1975 MCI 5B
1966 GM PD 4107 for sale
1968 GMC Carpenter
Offline Boomer
« Reply #3 on: September 04, 2013, 09:05:42 AM »
Silver Eagle Charters in Spokane.  They have or had a good shop and knew old buses.  They may not be around anymore though.
'81 Eagle 15/45, NO MORE
'47 GM PD3751-438
'65 Crown Atomic, NO MORE
Vancouver, WA USA
« Reply #4 on: September 04, 2013, 09:39:50 AM »
Northwestern Stage Lines if they are still around about 5 miles from Spokane
Online eagle19952
« Reply #5 on: September 04, 2013, 08:55:49 PM »
[urlhttp://northwesternstagelines.com/CompanyProfile/tabid/62/Default.aspx[/url]
4611 S. Ben Franklin Lane
Spokane, WA  99224
Phone          509-838-4029
Toll Free          800-366-6975
Offline Doug1968
« Reply #6 on: September 04, 2013, 09:24:38 PM »
Fellows,
Thanks for the info. I have forwarded this to a friend who is having the problems. I will post the results of what they find.
Thanks for all the responses!
Doug
Offline treeplanter
  • the grey ghost,1971 GMC 5305A
« Reply #7 on: September 04, 2013, 10:33:49 PM »
Try pacific power products ,http://www.pacificdda.com/ they are in spokane.
Timothy
