Author Topic: looking at a 4905A.....  (Read 9568 times)
Offline DaveNCari
  • Jr. Member
« on: September 06, 2013, 02:10:44 PM »
I have a chance to pick up a 4905A Buffalo Bus.....
What should one look out for...special problems with this beastie?
What does everyone think of that model?
Thanks!!!
Dave
Coming soon.....need of a bus-friendly RV park.....that values Liberty!
Watch this space....
Offline Bill B /bus
Re: looking at a 4905A.....
« Reply #1 on: September 06, 2013, 02:33:07 PM »
The flat floor after the steps is great. However, working around the step area takes a lot of thinking time. We converted a 4108. Worked ok but the steps are a problem. Ceiling height does not allow a 6'2" to pass under an AC without ducking. Typical of all GM's is the curves sides. If you are careful of installed weight then the tag axle could be pulled. Weight on two axles is 32,000#. Our 4108 weighed in at 28K# when loaded including three adults and one dog with full fuel and water.
Depending on location when in  service rust could be an issue.
Bill
Bill & Lynn
MCI102A3, Series 50 w/HT740
Online luvrbus
« Reply #2 on: September 06, 2013, 03:16:57 PM »
Those suckers do have some huge bays and the best power steering for ease of turning when parked I have ever been around the few I have driven I don't care for the ride or the handling,the standee windows and the rear window are what I see people having the most problems with they don't leak they pour
I am not much on problems with a 4905 like others here but one will drive you nuts with electrical problems when somebody has been bypassing and redoing the existing wiring system unlike most GM it has a 24v system
The tag was a option I have never saw but 1 over the years that came with a tag in the bay,the wheel base on those are 319 inches makes turning corners a chore in town other than having the wet clutch with the 4 speed just a GM bus
« Last Edit: September 06, 2013, 03:19:50 PM by luvrbus »
Offline Utahclaimjumper
« Reply #3 on: September 06, 2013, 04:34:02 PM »
 Some of the most comfortable and pleasing interiors I've seen have been 4905s, as said the storage bays are huge by any standard. Being aluminum construction they are not all that heavy for an 40 footer, the overall "look" is a mans machine.>>>Dan
Utclmjmpr
 EX 4106 (presently SOB)
Cedar City, Ut.
 72 VW Baja towed
Online luvrbus
« Reply #4 on: September 06, 2013, 05:12:02 PM »
The overall look is a mans machine is that the same as a man in bar looking at a ugly women at closing time Dan ::)
Offline RJ
« Reply #5 on: September 06, 2013, 05:41:01 PM »
Dave -
Sent you a PM. . .
RJ Long
PD4106-2784 No More
Cheney WA
Offline roadrunnertex
« Reply #6 on: September 06, 2013, 06:33:33 PM »
I have owned a P8M4905A Buffalo conversion for a number of years.
It's been a very trouble free coach.
I had the V730 transmission installed said good bye to the old Spicer.
I think the P8M4905's were a very nice driving coach with the Sheppard power steering.
The 24 volt electrical system has never been a problem for me.
I installed a voltage equalizer for the 12 volt requirements works well for me.
RRT
Offline 4905 doc
  • Jr. Member
« Reply #7 on: September 07, 2013, 03:42:16 PM »
Love them. If you have one with a tag, remove it and you have a great space for a black tank, furnace, and even propane. Plus, when I removed the tag on mine, I discovered I now owned some spare hubs, brake chambers and other assorted parts.  :)   I even grew to like the grumpy spicer 4 speed once I figured out how to sweet shift it.  8)
http://s991.photobucket.com/user/zion-dyi/library/bus?sort=6&page=1
Online luvrbus
« Reply #8 on: September 07, 2013, 04:15:09 PM »
You should raise the bus and be sure to check the rear radius rods I have friend his upper radius rod bracket is worn out on the axle housing and it is going to be a PITA to repair we have been studying for a year now to see how we can repair it ??? it is not going to be easy
 Now a ? for the GM guys with extra wheels in the 3rd bay ahead of the drivers would that not be a bogie instead of a tag
« Last Edit: September 07, 2013, 04:26:51 PM by luvrbus »
Offline pabusnut
  • P8M4905A-333 former MK&O lines #731
« Reply #9 on: September 07, 2013, 07:00:56 PM »
Look for rust around the windows, where the steel panels are.  Mine has two tiny holes rusted through, but are not a structural problem, and are patched over(not pretty).
Also check for a cracked rear bulkhead, especially if it has an automatic transmission.
Mine had a "bogie" axle in the third bay, which I removed and built a floor.  This bay now houses all my tanks, electrical panels, batteries,and propane tanks.  It was a tight fit, but with a little ingenuity, it all fits!
The front "stadium seating" is not a problem for me, since I always wanted to keep some of the "bus" look and haul more than just one or two passengers.  I kept first four seats on the passenger side.  I think it will also be a good place to watch a projection tv(from a a computer) on a screen on the inside of the front window.
If you like that style bus, and it is in good condition -- go for it.  Remember you will never get out of it(money wise) what you put into it(an old bus), but there are intangibles that can't be measured.
Steve Toomey
Steve Toomey
PAbusnut
Offline johnjem
  • http://photobucket.com/johnsgmc4905
  • 1970 gmc 4905
« Reply #10 on: September 08, 2013, 04:24:23 AM »
I will sell my 1970 4905  to u!!!!
 johnjem84@yahoo.com
Never stop thinking,it"s what keeps us going till tomorrow
Offline DaveNCari
  • Jr. Member
« Reply #11 on: September 08, 2013, 10:42:16 AM »
If you gave it to me...it would cost me more to drive it to WA that I can get this one for....   ;-)
Dave
Offline chessie4905
« Reply #12 on: September 08, 2013, 05:30:24 PM »
   Pull the side panel on left side of driver's seat and check for rusty/ corroded wiring. Does the coach run, is it drive-able?
Offline DaveNCari
  • Jr. Member
« Reply #13 on: September 09, 2013, 01:11:18 AM »
It does run...I am going to go drive it and go over it thoroughly next week.....
Dave
Offline tuccitown
  • Jr. Member
« Reply #14 on: September 09, 2013, 02:25:31 PM »
If you need a hand let me know, I have a '79. Where are you in WA? I'm in Seattle.
Jack
1979 GMC H8H649-053 Conversion in progress.
1955 GM PD 4501-377 Converted.
