June 23, 2018, 12:28:19 PM
Author Topic: How to Bus build book  (Read 6366 times)
Offline Geoff
Re: How to Bus build book
« Reply #15 on: September 11, 2013, 04:03:16 PM »
Im redoing a coach, and it's a mess with both 12 and 24 volt system, and none of the wiring is marked
I thought I disconnected all the 24v wiring when you had your bus over here.  Everything should be 12v, you just have a lot of left-over relays that aren't doing anything.  You need to get 4 batteries in the left side battery compartment (I recommend 4 6v golf carts hooked for 12v to run your house system).  Corroded wiring in the driver's area is a matter of rewiring.  Everything should be 12v.
--Geoff
Geoff
'82 RTS AZ
Offline harleyman_1000
    • My bus
« Reply #16 on: September 12, 2013, 01:17:24 AM »
--Geoff
 Yes Geoff you did, and now I want to remove all the 24 volt wiring and relays that aren't being used. I want to have the genset charge the batteries when it's running. I am thinking on just rewiring a new house battery system, but not removing the old wiring untill I see if my wiring works  ::)
Scott
St.Louis Missouri
Offline Melbo
  • MC8 under construction
« Reply #17 on: September 12, 2013, 01:35:19 AM »
PM me an address and I will send you a book about RV wiring that I read and no longer use.
Melbo
