Author Topic: blew the inside drive axel tire today!  (Read 4345 times)
Offline Dlsnow
  • dave
  • dave
« on: October 17, 2013, 12:39:11 PM »
Blew the inside drive Axel tire.  On I40 today.  We are safely parked outside a truck stop now.  Waiting on the tire guy.  Looks like all my drive Axel tires are weather checked and need replacement.
I am not sure if this setup is normal but here is what I have
Drive Axel tires 12r 22.5 Lth
Tag Axel tires 315/80 22.5 Lth
Steer tires 295/75r22.5 lrg
For now I am replacing it with the same 12r22.5 but when I buy all new drive tires ($$$$$) what should I have?
1972 MCI7 8v71 converted - 1kw solar on roof
  • Gold Donor
Re: blew the inside drive axel tire today!
« Reply #1 on: October 17, 2013, 12:45:13 PM »
Lol you will enjoy the answers this generates
Offline Dlsnow
  • dave
  • dave
« Reply #2 on: October 17, 2013, 12:51:31 PM »
Oh did I just ask the "what oil should I use" question?
I didn't mean to but I realize the investment I am about to put in tires and want to make the best decision I can.
Offline thomasinnv
  • Derrick Thomas
Re: Re: blew the inside drive axel tire today!
« Reply #3 on: October 17, 2013, 01:08:16 PM »
I did what some other folks have done. I went to 11r22.5 tires. They run a few more revs per mile and the speedo is off by just a couple mph at highway speeds, but the price was about half per tire
Sent from my PantechP9070 using Tapatalk 4 Beta
1998 MCI 102-DL3
Series 60 12.7/Alison B500
Offline bevans6
  • 1980 MCI MC-5C
« Reply #4 on: October 17, 2013, 01:46:47 PM »
When I have to finally replace tires I will probably go to 11R-22.5, since they are near to the right size and can support the weight.  It (and mine) would probably do better ride and tire life wise with 12R-22.5, but the cost for us is different than the cost to a bus company.
Offline Dlsnow
  • dave
  • dave
« Reply #5 on: October 17, 2013, 01:50:44 PM »
Well I have someone's cousins son here putting the tire on.
I have never seen a tire put on the bead by filling it with starter spray and lighting it.  But the tire seated and is being mounted now.
Offline Eagle Andy
  • Cowboy Coach
  • 1968 Silver Eagle # 7481
« Reply #6 on: October 17, 2013, 02:12:16 PM »
Yup that's how it's done the old school way  :o just make sure you don't put to much either in there ;D
Offline TexasBorderDude
  • Founder - Texas Curmudgeon Society
  • Nothing simple is ever easy...
    • WheresDoyle
« Reply #7 on: October 17, 2013, 03:48:44 PM »
Well I have someone's cousins son here putting the tire on.....
I would venture a bet that south of the Mason-Dixon line, just about every person mounting a truck tire is someone's cousins son ;D ;D ;D
A curmudgeon's reputation for malevolence is undeserved. They're neither warped nor evil at heart. They don't hate mankind, just mankind's absurdities. They're just as sensitive and soft-hearted as the next guy, but they hide their vulnerability beneath a crust of misanthropy.
Offline wg4t50
« Reply #8 on: October 17, 2013, 05:21:02 PM »
Agree on the 11R 22.5, and of course the ether to seat the bead, but have you seen a guy throw a 22.5 alum rim into the tire, did both sides in one swing, like magic, would have not thought it possible until I watched a young gent in Madison Wi, do it at a truck stop. Lots to be learned around some shops.
Dave M
MCI7 20+ Yrs
Foretravel w/ISM500
WG4T CW for ever.
Central Virginia
Offline RJ
  • Vantarè Conversion "Vivian"
« Reply #9 on: October 17, 2013, 07:18:34 PM »
Dave -
Be aware that the HD truck tire industry is rapidly changing to metric sizing, like we've had on our cars for a dozen years or more.  So it's a little more involved than just walking into a store and sayin' "Put tires on my bus."
One thing to take into consideration is "tire revs per mile."  The stock size for your MCI was 12.00R22.5, and that's what MCI designed the powertrain around.  Thus to keep stock performance, you want to run tires that approximate the same RPM as the OEM tire.  This will mean a little homework on your part, to find the average revs per mile for 12R22.5s among the various manufacturers.  That will then become your baseline to work off of.
More RPM = lower top speed and greater fuel consumption.
Lower RPM has the opposite effect.
Then start comparing the "old" sizing nomenclature with the new metric sizing to find something equivalent or suitable.   Once you've decided, then start shopping price.
Make sense?
RJ Long
PD4106-2784: Donated to the Pacific Bus Museum
S14947: 1980 MC-5C Shell 6V92/HT-740
S13406: 1978 MC-5C Angola Coach - Swapped for vvv
M1001907: 1992 Prevost XL Vantarè Conversion 8V92T/HT-755 (DDEC/ATEC)
Cheney WA
« Reply #10 on: October 17, 2013, 10:13:25 PM »
What tires the bus came with and what tires you should use is determined by weighing the bus by axle. I think you'll find that you'll be able to use the same 11R-22.5's all around. But-once again-weighing is the way to find out. Good luck, TomC
Offline Jerry32
« Reply #11 on: October 18, 2013, 09:07:43 AM »
I put 11R24.5 tires and wheels on to keep up the ground clearance. and keep the revs down. Jerry
1988 MCI 102A3 8V92TA 740
