Author Topic: looking for 4106 4 spd trans  (Read 5908 times)
Online chessie4905
  • Platinum Donor
Re: looking for 4106 4 spd trans
« Reply #15 on: October 23, 2013, 06:24:22 AM »
  Aligning that V? You don't need to change shims just to take apart and replace that front bearing assy. Those trans are pretty simple inside and parts are large. They aren't delicate like a car or truck trans. Normal wear isn't going to effect reliability. You can make gaskets or use silicone in some places. Just follow repair manual for taking it apart. Only disassemble enough to replace front bearing and turn over and flush out any debris. If you don't feel comfortable doing it yourself, Find an independant place that repairs truck trans. Just tell him you want it repaired, not rebuilt.
Offline Red Rider
  • God put me here to accomplish certain things--- I'm so far behind I'll never die.
« Reply #16 on: October 23, 2013, 01:15:43 PM »
I thought it would be polite to post a follow-up since so many of you folks provided assistance.
After further investigation we found the main drive gear missing approx 50% of it's teeth. The front carrier bearing as fused to the shaft and took 50,000 lbs to press it off. The race is "welded" to the case. Half of the rollers from the inner bearing was made into shrapnel and was on the drain plug magnet. It looks like the idea of putting in some replacement bearing went south.
I called Luke to see what his opinion might be and he felt that I should look for a replacement trans.
Still looking for an 06, V drive, four speed.
Thanks again.
Mike AKA; Red Rider 4106-1885
  • Gold Donor
« Reply #17 on: October 23, 2013, 01:45:20 PM »
 Mike now you know for sure
« Last Edit: October 24, 2013, 04:31:23 AM by luvrbus »
Offline Boomer
« Reply #18 on: October 23, 2013, 08:56:16 PM »
The double clutching method may be required.  LOL
'81 Eagle 15/45, NO MORE
'47 GM PD3751-438, NO MORE
'65 Crown Atomic, NO MORE
Vancouver, WA USA
Offline Red Rider
« Reply #19 on: October 24, 2013, 06:04:18 AM »
Boomer;
Does that mean I'm supposed to push the clutch in when I shift? LOL
  • Gold Donor
« Reply #20 on: October 24, 2013, 06:12:33 AM »
Mikey you need to stop driving the bus up on the lowboy let the wrecker driver use the winch how do tear up a transmission that bus is always riding every time I see it ::)
Offline saddleup
« Reply #21 on: October 24, 2013, 06:57:10 AM »
Also, he neads to make sure the trany out of gear when the big wrecker draging it out of the sand...lol
Yuma,Az
Offline olebusman
  • Jr. Member
« Reply #22 on: October 24, 2013, 07:23:17 AM »
 Hey Red Rider  I have a 4106 4 speed with a 1 year old clutch and a 8v71 all on a cradle mouted on a dolly to roll in a engine compartment. The trans was gone thru. The needle bearings alone were over $300.00 dollars. Come and get it $1000.00  olebusman ps The clutch was over $1000.00 complete with flywheel face insert
Offline Boomer
« Reply #23 on: October 24, 2013, 08:06:21 AM »
Ted Campbell probably has one.
Vancouver, WA USA
Offline Red Rider
« Reply #24 on: October 24, 2013, 04:37:14 PM »
Thank you everybody. I have committed to buying a dry clutch 06 set up. We found it in Southern AZ. The seller has a fine reputation and comes highly recommended. He is parting out his Bus and the folks who bought the engine are very pleased.
There are no new 06 trannys around so this will have to work.
Matt: Obviously I had the clutch in. How else can you bury a 06 all the way to the axle in the sand?
Offline Liberty
« Reply #25 on: October 24, 2013, 04:51:00 PM »
As far as the sand goes I think it was the GPS not the driver. I mean who knew there was a river there.
LeRoy
Offline Red Rider
« Reply #26 on: October 24, 2013, 06:18:53 PM »
OK Leroy, be nice.
  • Gold Donor
« Reply #27 on: October 24, 2013, 06:32:12 PM »
Who ever knew AZ was in CA  lol you will never live that down Mikey
Offline Red Rider
« Reply #28 on: October 24, 2013, 06:37:35 PM »
Hey Clifford,
A wise man once said "you get what you deserve". I really think it all your fault. If I hadn't been going to visit you I wouldn't have run into the Colorado River. :)
With that logic I should run for congress.
