June 23, 2018, 12:58:04 PM
Author Topic: leaky brake valve  (Read 1121 times)
Offline David Anderson
leaky brake valve
« on: November 26, 2013, 01:08:44 AM »
The foot pedal brake valve is leaking badly in my eagle.  I noticed it when I returned from a trip last week.  My air pressure would drop from 120 to 0 in about 10 minutes.  I spent the better part of the afternoon trying to get the valve out.  No success yet.  It is really hard to get to the bolts.
When I get it out I think it probably should be replaced.  Don't want to tinker with something so important and possibly have it fail :o and turn the coach into a 36k pound ram.
I will work on it some more tomorrow.
David
Offline Brian Diehl
    • www.brihil.com
Re: leaky brake valve
« Reply #1 on: November 26, 2013, 02:39:13 AM »
I agree - just replace the valve.  A number of years back I had a leaking valve as well.  JD @ C&J Bus recommended are replacement instead of rebuilding.  I haven't regretted it.
Online luvrbus
« Reply #2 on: November 26, 2013, 08:21:37 AM »
It shouldn't be that hard David unless you are try to remove the whole assembly the valve only has 3 bolts holding it to the pedal assembly
« Reply #3 on: November 27, 2013, 02:16:59 AM »
I didn't have time to get to it today.  I saw those three bolts, took the nuts off two, but haven't gotten to the 3rd one.  I started to disassemble the foot pedal on the top side.  I guess I should stop that and make every attempt to get the 3rd bolt.
