Author Topic: Need a Turbo Rebuild  (Read 5373 times)
Offline eagle19952
Re: Re: Need a Turbo Rebuild
« Reply #15 on: December 02, 2013, 07:07:38 PM »
Geoff-
Are you referring to the location of the clamp holding the intake hose on the turbo inlet?
I am certain he is, there is a possibility (one worth checking) the horn that the intake hose seats on is not very wide, you could be clamping it on the edge, which could be allowing in dirt.....that would not cause a power loss (imo)....quick check...squirt a nickels worth of ether at the air intake side of your turbo....and listen.
A turbo usually makes a screechy noise going out...them nothing.
pull the easy side and  look for chipped or malformed fins...see if there is shaft play. That turbo looks like it is on bolts vs. studs, you should be able to peak at the hot side easily too. there isn't much to a turbo. spins free, it's all there, it should be good.
IF you need one (a turbo) get an exchange....you have no way of knowing the condition otherwise...my .02 and worth about that.
Offline eagle19952
« Reply #16 on: December 02, 2013, 07:14:41 PM »
Here's another thought, go to a turbo shop and ask to look at (feel) what a properly setup turbo feels like...big or small they pretty much all run on the same tolerances, then go feel yours...you really don't need much more experience than that, again, imo.
Unless you want a different power response....then I would listen to anyone but me.....:)
Offline Lee Bradley
« Reply #17 on: December 02, 2013, 10:46:41 PM »
Looks like the clamp is a couple of inches out on the hose from the turbo housing and it has been tightened down so much that the hose is noticeable reduced in size.  That would restrict the air
flow and disturb the air flow into the compressor side. I would remove that hose section and see if the hose recovers if not replace that section.
Offline eagle19952
« Reply #18 on: December 03, 2013, 08:24:13 AM »
are you serious ? ??? ??? ??? ??? ::) ??? ??? ??? ???
Offline Don Fairchild
« Reply #19 on: December 03, 2013, 09:26:06 AM »
Seangie, I just sent you a pm.
Don
Online chessie4905
« Reply #20 on: December 03, 2013, 07:05:34 PM »
Maybe this will help some. They are talking about car turbos, but the info is pretty much the same:
Turbo Turbocharger Shaft Play
