Author Topic: I need a manual for my 6v92 engine that came out of a MCI9  (Read 2757 times)
Offline harleyman_1000
    • My bus
« on: December 02, 2013, 01:31:37 PM »
 Does anyone know where I can get a manual for a 6v92? I have a engine out of a MCI9 in my GM 4104 I need a manual for this engine.
Scott
St.Louis Missouri
Offline jimsflx
Re: I need a manual for my 6v92 engine that came out of a MCI9
« Reply #1 on: December 02, 2013, 01:44:32 PM »
I have the complete set of 3detroit diesel books. email me off line. thanks
jim&roenie seagraves sebring fl. 4106-3083
Online luvrbus
« Reply #2 on: December 02, 2013, 01:53:51 PM »
If that fails with Jim I have a set of 92 series manuals also, no such thing as just a 6v92 the manuals contain all the 92 series the 6v92,8v92,12v92 and 16v92
Offline Seangie
  • www.herdofturtles.org
    • Herd of Turtles
« Reply #3 on: December 02, 2013, 02:03:02 PM »
Scott,
I have a Detroit Diesel 92 series folder full of documents pertaining to the 92 series engine including the engine and servicing the engine.  Its about 500megs though.  I could mail it to you on a USB drive.  Not sure I have enough bandwidth to upload 500megs in any given time.
I do think I found it from a shared folder somewhere here in bus cyberspace.  Im sure someone else knows where I found it but if you cannot find it or for some reason Jim cannot get it to you, let me know via PM and I'll snail mail a USB/PDF copy to you.
'Cause you know we,
Driving through the night
To that old promised land'
    • My bus
« Reply #4 on: December 02, 2013, 02:50:08 PM »
 Ok well Im needing what would help me to know how to work on my engine? For example I need to remove the water pump, and there is a large C clamp looking piece that seems to be holding it on and Im wondering is there a spring or something behind that, that will shoot out?  Please remember as this is probably a very stupid question, this will be my first time working on the engine, and I would rather be safe.
Scott
St.Louis Missouri
Offline Geoff
« Reply #5 on: December 02, 2013, 04:28:52 PM »
Why do you think you need to take off the water pump?  The snap ring you mention has nothing to do with taking the water pump off, there are three bolts holding it to the engine, plus the hoses.  You only need to take the snap ring off the cover if you are going to rebuild the pump.
--Geoff
Geoff
'82 RTS AZ
    • My bus
« Reply #6 on: December 02, 2013, 05:38:18 PM »
The water pump is starting to leak   :(
Scott
St.Louis Missouri
Online luvrbus
« Reply #7 on: December 02, 2013, 06:06:13 PM »
You can install the seal from the front by removing the snap ring and cover nothing in there that bites if the shaft and bearings are bad the pump needs to be removed for those to be replaced The seal is 8 bucks and the whole kits are some where around 80 to 125 depending where you buy Mohawk is the cheapest on the kits
« Last Edit: December 02, 2013, 06:22:12 PM by luvrbus »
Offline Eagle Andy
  • Cowboy Coach
  • 1968 Silver Eagle # 7481
« Reply #8 on: December 02, 2013, 06:32:28 PM »
It is quite easy to remove the pump, like stated three bolts and the hoses. When i bought a new pump from DD the new snap ring needed to be installed. Not hard I just used a large pair of curved needle nose pilers.
Offline B_K
« Reply #9 on: December 02, 2013, 09:02:51 PM »
Scott give these folks a call. They have every part ever offered by Detroit.
http://midwestdieselservice.com/
Guy once told my dad "if we don't have it's only because my wife doesn't know it exists!"
;D  BK  ;D
