Author Topic: Get your bus out of the mud with a winch!  (Read 12975 times)
Offline Oregonconversion
    • Somethingforever.com
« on: December 04, 2013, 11:02:36 AM »
My bus is not stuck, this is just a question I have been thinking about.
Hypothetically speaking... how large of a winch would you need to pull a converted MCI bus out of the mud.
Im not talking buried tires, just slipping and starting to dig in a little.
I know this is a loaded question, but it will be fun to see the different answers from all you bus nuts.  ;D
My guess is a 12,000 pound wench would do it. I have never tried this, so its JUST a guess!  :D
1977 MC8
8V92 HT740
Offline Red Rider
  • God put me here to accomplish certain things--- I'm so far behind I'll never die.
Re: Get your bus out of the mud with a winch!
« Reply #1 on: December 04, 2013, 11:05:37 AM »
When I stuck my 4106 in the sand and near Clifford's , I called coach net. I don't think that's the answer you where looking for but it worked.
Mike AKA; Red Rider 4106-1885
Offline akroyaleagle
« Reply #2 on: December 04, 2013, 11:08:17 AM »
Probably wouldn't take much of a winch if it wasn't buried. Try raising the tag to put more weight on the drive.
I would be more concerned about the size of the winch cable. If you snap that near the winch, it will
redecorate the front of the bus and the windshield. Probably a lot more.
Joe Laird
'78 Eagle
Sioux Falls, South Dakota
« Reply #3 on: December 04, 2013, 11:09:17 AM »
I was thinking you could drive a giant stake into the ground and attach the winch onto it if there were not any trees around.
1977 MC8
8V92 HT740
HighTechRedneck
« Reply #4 on: December 04, 2013, 11:11:12 AM »
I think to deal with almost any degree of stuck, it might take more than a 12,000 pound winch and if the ground was soft enough to sink into, it probably won't hold a post you can drive in to the ground well enough to take that kind of force.  Especially since buses don't seem to barely get stuck very often.   Now with a
12,000 pound wench
I just don't know.  Maybe???   ;D
« Reply #5 on: December 04, 2013, 11:13:36 AM »
Well if a truck that was rated for towing 10,000 pounds can move a 300,000 pound space shuttle, then this makes sense? LOL
1977 MC8
8V92 HT740
« Reply #6 on: December 04, 2013, 11:14:57 AM »
haha! Winch!
1977 MC8
8V92 HT740
HighTechRedneck
« Reply #7 on: December 04, 2013, 11:26:33 AM »
That is a good point.  On the other hand, that situation is high pressure tires on a hard smooth surface.  Minimal rolling resistance.   But just jamb one of the shuttle's wheels with block of wood and I would just about bet that truck would be out of luck.
Next think about pushing a car yourself. On smooth flat ground no problem.  Add grass it gets a little harder.  Ad softness to the ground and it gets a lot harder.  Mire a tire, forget it.
On flat ground we use pickups to reposition no operating buses here on the shops lot.  But they wouldn't stand a chance if one or more wheels got into the ground a bit.
« Reply #8 on: December 04, 2013, 11:30:13 AM »
Great point!
buuuttt.....
The ratio of 300,000 - 10,000 is 30
The radio of 40,000 -12,000 is about 3.33!!!!
1977 MC8
8V92 HT740
« Reply #9 on: December 04, 2013, 11:30:52 AM »
Quick, someone go get stuck!
1977 MC8
8V92 HT740
HighTechRedneck
« Reply #10 on: December 04, 2013, 11:37:13 AM »
Great point!
buuuttt.....
True.  And if the bus is only a little stuck, it would probably only multiply the force 3 or 4 times.  But if the tire got sunk in perhaps 8 inches or so, I think we are dealing with exponentials there.  lol
« Reply #11 on: December 04, 2013, 11:38:57 AM »
Also you don't have the slip factor that a vehicle with wheels would have.
1977 MC8
8V92 HT740
Offline rusty
« Reply #12 on: December 04, 2013, 11:57:55 AM »
Three or four part the line it will get it out. Two problems make sure you try it to something heavier than the bus and you don't pull the bus in two.
Wayne
Offline Utahclaimjumper
« Reply #13 on: December 04, 2013, 12:01:26 PM »
 You would be amazed at what a good "snatch strap" and a pick-up can do to "unstick" a bus.>>>Dan
Utclmjmpr
 EX 4106 (presently SOB)
Cedar City, Ut.
 72 VW Baja towed
Offline Oonrahnjay
« Reply #14 on: December 04, 2013, 12:08:50 PM »
     Only if a farmer was paying you to plow a field.  I've had to pull out lots of Land Rovers that were "barely stuck" -- we almost never had any luck with driven anchors or "ground anchors" or anything other than a very solid object.  Almost any load will pull the stake (even a "giant" one) right out.
     One thing that we did do was put a couple of floor mats or a folded blanket etc over the winch cable.  If the cable breaks if you do this, you'll probably only take out one headlight and one windshield panel instead of everything on the front of the bus.    ::)   ;)
     In the right situation, with the right set up (particularly if you can get any "drive" from the stuck vehicle itself), a winch seems to work miracles.  If you have anything working against you (uphill, deep sunk tires, no anchor point, no way to get a good angle on the pull. etc.), you can pull all day and just waste your time (at best -- or really bust something up, at worst).
