Author Topic: Looking for a cheap toad  (Read 20523 times)
Offline Tikvah
    • Dave & Amy
« on: December 10, 2013, 03:30:35 PM »
The title say it... I don't want to spend much, but need a light-weight car with the hardware to tow behind my MCI.
I'll be at Arciada, if you have one to give away, I'm your man   ;D
1989 MCI-102 A3
DD 6V92 Turbo, Alison
Tons of stuff to learn!
http://dave-amy.com/
Offline RJ
Re: Looking for a cheap toad
« Reply #1 on: December 10, 2013, 06:14:22 PM »
VW Golf or Jetta (TDI a plus), but only with a manual gearbox.
Saturns with an automatic can be flat towed.
Honda CR-Vs, either two- or four-wheel drive can also be flat towed with an automatic.
Just some of the more popular toads.
RJ Long
PD4106-2784 No More
Cheney WA
Offline wg4t50
« Reply #2 on: December 10, 2013, 08:22:12 PM »
Have towed with good results;
VW Rabbit Diesel 4 speed
Ford Escort 5 speed
Honda Element auto
Ford F150 2 wheel drive with 5 speed Mazda gear box, Ford says no way, with over 10 k miles towing, I have zero issues.
Honda CRV auto
Liked the VW Rabbit the best, was happy to arrive and it still there, if it got lost
         would be OK as long as it did not hurt anyone. Kept the title in glove box.
MCI7 20+ Yrs
Foretravel w/ISM500
WG4T CW for ever.
Central Virginia
Offline sledhead
« Reply #3 on: December 11, 2013, 04:56:27 AM »
ford ranger 5 speed standard
changed trans , rear end oil to syn oil .
4 years no problems
dave
dave , karen
Offline Ed Hackenbruch
« Reply #4 on: December 11, 2013, 05:06:11 AM »
 Older Jeep Cherokee's ..... seats 4 or 5, fold down rear seat for more cargo room, can tow 4 down even if it is a 4x4, less than 4000 lbs.  Lots of them around still and can be bought fairly cheaply.
Used to own a 1968 MCI 5A with 8V71 and Allison MT644 transmission.
Offline scanzel
« Reply #5 on: December 11, 2013, 05:20:41 AM »
Jeep Cherokee Sport, just sold my 220,000 mile used one and bought a 2008 Jeep Liberty. Try Cherokee or a Liberty can still be towed 4 down. Grand Cherokee can be towed 4 down but must find one with the proper auto trans. Quadra Trak, must be able to put transfer case in neutral.
Steve Canzellarini
Berlin, CT
1989 Prevost XL
Offline muldoonman
  • 1991 Prevost 8V92TA
« Reply #6 on: December 11, 2013, 05:25:30 AM »
Don't know about older but flat towed my 2010 Ford Edge front wheel drive automatic trans, all over Texas. Wish I would have know you needed one. Just traded in with all Falcon hardware to Ford Dealership.
Offline Mex-Busnut
« Reply #7 on: December 11, 2013, 05:29:25 AM »
We have a 2007 Jetta TDI, 1.9-liter engine, 5-speed standard tranny. (50 mpg or better on the highway!) Can it be towed 4 down without problems?
Jake brakes
Offline Oonrahnjay
« Reply #8 on: December 11, 2013, 07:20:58 AM »
     The '07 in Mexico is still the A4 body style for the Jetta, I think.  (In the US, the Jetta switched to the bigger, heavier, more complicated A5 body for the "2005 1/2 model year".)  If I'm right on that, then you have the same engine (ALH, if it's the 'distributed injection' Bosch fuel pump-equipped engine) and transmission that I have in my 2003 Jetta.  VW says not to tow that model with four wheels down because the lubrication for the transmission is supposed to be driven by the shaft coming in from the clutch -- when the transmission is in neutral, that shaft doesn't turn.  But a number of us HAVE towed manual transmission VW's (and the 5-speed is basically the same transmission as the 4-speed going way back to the 80's) for many miles* and I've never seen anyone report ill effects.  I think that due to the fact that the transmission is running "unloaded" when it's being towed in neutral and there's plenty of splash lubrication, there is enough lubrication in and throughout the transmission to make things OK.
(Note: to be absolutely clear, I personally have only towed mine a couple of thousand miles with no problems; others have reported towing many thousands of miles, no problems.)
     Hope this helps (and Merry Christmas - and Feliz etc. down there).   B  H    NC   USA
Offline chessie4905
« Reply #9 on: December 11, 2013, 07:39:57 AM »
  I tow this: cheap, 4wd, auto, compact, and relatively light weight. It has a hardtop and I added lockout front hubs. I'm planning a trip to Alaska in two years and wanted something I could use there to run around on lesser roads and a small vehicle for towing. With the 4wd low range, I'll be able to tow the coach out of any soggy fields also.... ::)
http://autos.msn.com/research/vip/Spec_Glance.aspx?year=2003&make=Suzuki&model=Vitara
There! forgot to add it when I originally posted.
« Last Edit: December 11, 2013, 02:54:04 PM by chessie4905 »
Offline B_K
« Reply #10 on: December 11, 2013, 07:51:12 AM »
What is it? (too small to see!)
Offline Lin
  • 1965 MC-5a
« Reply #11 on: December 11, 2013, 07:56:11 AM »
Chessie, What's a this? I didn't see a picture.
We tow a 99 Cherokee.  There are lighter vehicles, but it is nice to have a solid 4x4 automatic when we get there.  Ours was bought used 4-5 years back for about $2500.  It is now just about ready to cross the 200,000 mark.  Apparently, the 4.0 engine has a reputation for more mileage than that.  It is not great on gas though.
Offline challenger440
    • Mountainstar video Productions
« Reply #12 on: December 11, 2013, 09:58:35 AM »
I had a this, then I traded it for a that.  I don't like the that as well as my this.  So if you have a choice between this and that, take the this.  John M :D
John M.
Helena, Mt
MC7  "under construction"
Offline Tikvah
    • Dave & Amy
« Reply #13 on: December 11, 2013, 10:07:04 AM »
thanks John, I hadn't thought of That.
anyone tow a VW beetle manual?  the modern kind, not the air cooled.
1989 MCI-102 A3
Offline chessie4905
« Reply #14 on: December 11, 2013, 02:59:09 PM »
   I have a 2003 TDI Jetta, but won't tow it because it doesn't have sufficient ground clearance. There are several reports on the web of taking out the oil pan from some larger debris. It won't straddle a medium dead groundhog.
