June 25, 2018, 03:11:03 AM
Author Topic: Mini-split update  (Read 10162 times)
Offline Tikvah
    • Dave & Amy
Mini-split update
« on: January 07, 2014, 05:45:01 AM »
I finished the mini-split install yesterday.  Turned it on and we have been totally amazed at how much air it moves almost silently.  Even the outside unit is almost impossible to hear standing next to it.  We're impressed!
Then the test.  Here in central Florida we woke to 27 degrees this morning.  Great night to test the heat side of the unit.  I couldn't believe how warm we were during the night.  It easily maintained 74 degrees all night.  The heat was even and comfortable.  The next test will be the next wave of hot weather.
Now my question.  We had 25% humidity during the night.  That's pretty good in a land that is always humid.  But we still have terrible condensation from our windows and roof vents.  This condensation is going to rot my wood and rust my steel if we can't get it controlled.  Any ideas?  We spend our mornings (when it's cold) moving around the coach sopping up water.  This isn't good.  I figured 25% was good but it isn't.  What do I do?  Will a dehumidifier work?
Dave
1989 MCI-102 A3
DD 6V92 Turbo, Alison
Tons of stuff to learn!
http://dave-amy.com/
Re: Mini-split update
« Reply #1 on: January 07, 2014, 06:07:55 AM »
They don't dehumidify in the heating mode a dehumidifier is the only choice you have or a rain coat @ 34 degrees with 80% humidity that is why a defroster on automobiles has the AC tied into the heat fwiw
« Last Edit: January 07, 2014, 07:17:59 AM by luvrbus »
Offline Dave5Cs
Re: Re: Mini-split update
« Reply #2 on: January 07, 2014, 06:14:54 AM »
Dave try opening a vent and or slightly open a window. Should help get rid of some of it.
Dave5Cs from Galaxy S III
"PATHFINDER"(Bus)
Toed 1998 Jeep TJ
Offline Oonrahnjay
« Reply #3 on: January 07, 2014, 07:01:51 AM »
  Dave try opening a vent and or slightly open a window. Should help get rid of some of it.      Dave5Cs from Galaxy S III
     Right, and everyone knows that hot air rises but not a lot of people know that water vapor is about 70% the density of air (at the same temperature).  So, moisture rises, too*.  Open the highest vent you can -- but be aware, if you have a vent open enough to move a lot of moisture out, you lose a lot of your $$heat$$, too.
(*  OK, it's not really quite that simple in real life since you have a mixture of air and water vapor in any artifically heated volume but it makes a difference and the principle is correct.)
Offline Zeroclearance
« Reply #4 on: January 07, 2014, 08:29:36 AM »
Dave, the best investment that I made was buying a small 110v dehumidifier.  You can catch them on sale at Lowes or other box store.   I run it 24/7.   It is amazing how it changes and maintains the humidity level that you set it to.
Offline bevans6
  • 1980 MCI MC-5C
« Reply #5 on: January 07, 2014, 09:08:15 AM »
Get the kind that has a hose connection for discharge, that way you can let it drain directly outside.
« Reply #6 on: January 07, 2014, 10:07:46 AM »
Most of the larger units have the hose drain hook up.   I never has used it.  I have the larger unit, with 2 gallons of capacity.  It will run 3 days before it shuts off at the high level limit and that's in the rainy Pacific NW..    Basically, they are closed loop mini heat pumps.   You do net out some heat out in the process.
Offline robertglines1
  • steam nut
« Reply #7 on: January 07, 2014, 01:56:20 PM »
First Ac day close your bus up tight and run the unit around 62(lowest setting ) if I remember rite.  dry it out once.. Might help in future..You  will be surprised how well they draw moisture out.. If you are the type that can't do that.. the part of Florida your in is up and down this time of year .  Fires one week--floods the next..Fire season coming up if I remember correctly--then more rain about 3 months later.
Offline Iceni John
« Reply #8 on: January 07, 2014, 03:29:48 PM »
Dave,
What make and model is your mini-split?   How much power does it take to start and run it?
2kW of tiltable solar on the roof.
Offline Tikvah
    • Dave & Amy
« Reply #9 on: January 07, 2014, 05:18:15 PM »
http://www.minisplitshop.com/store/product.php?productid=261&cat=0&page=1
Right now I can't imagine building a bus with anything other than a mini-split.  We are set to install a second one, but not sure if we will need it or not.
1989 MCI-102 A3
Offline dukegrad98
« Reply #10 on: January 07, 2014, 05:52:25 PM »
I had a very negative purchase experience with this website.  I bought three units from them (also Soleus), and when one had a dead screen upon installation, they will not return any of my calls or e-mails.  I would NOT do any kind of business with them again.  Just a heads-up for anyone else thinking about taking the mini-split plunge.
The unit still fundamentally works, but the temperature readout does not work at all.
Cheers, John
« Last Edit: January 07, 2014, 05:56:19 PM by dukegrad98 »
Offline Mex-Busnut
« Reply #11 on: January 07, 2014, 07:34:23 PM »
We also put in miniplits: Two of them. (See details in our bus build thread here: http://www.busconversions.com/bbs/index.php?topic=22081.0
In my humble opinion, you might do great with just one minisplit if:
   1. It is just you and your spouse traveling (more people = more heat generated)
   2. You don't frequent places with temps above 100.
   3. Your bus is well-insulated.
My two pesos' worth.
Jake brakes
Offline Oonrahnjay
« Reply #12 on: January 07, 2014, 07:38:45 PM »
  ...Right now I can't imagine building a bus with anything other than a mini-split.  ...
    I was looking at the 12K BTU unit but at a price of $499 for the 9K, it's hard to beat.  I'm sorry to hear about "DukeGrad"'s experience, tho; that's worrying.
Offline Oonrahnjay
« Reply #13 on: January 07, 2014, 07:42:27 PM »
  ...  In my humble opinion, you might do great with just one minisplit if:
   1. It is just you and your spouse traveling (more people = more heat generated) ...
      Or if your bus-house is a single story!
Offline Mex-Busnut
« Reply #14 on: January 07, 2014, 08:22:52 PM »
Ahhh yes. I believe only two buses on these forums are multi-story single family dwellings. And Mine might be one of only a few with a basement bedroom.
 ;D
Jake brakes
