Just how fast are you willing to afford ? Its just a $$$$$ thing.Local wacko balanced his 8V-92, cleaned up heads, port matched exhaust manifolds, 145 injectors, unknown turbo that make massive boost, Governor at 2800 rpm, in a Senicrusier.How bad do you want the big power ?Dave M
Agree on slow & needing to pee ! However as I get the picture, your vehicle is suffering from lack of a mechanic, nothing in good order will run the speed your talking about. Hell a 318 DDC with 73,280 lbs runs 28 mph on mountains, that is slow, not " under 10 mph".Don't think you can wish your way to running better, find a shop that likes DDC engines and geterdone, you will be happier. Forget the 425 hp outa that critter, that is a dream.Dave M
I don't mean that to sound like a whine, but as an observation. With so many years of service, I was expecting to see at least a few "kits" or "packages" available on the open market. Rebuild kits with stronger components that let you get that 425 with some longevity...etc.It's just something I wanted to mention.Sean
I think is where I got the idea about the 425 hp dream ?Agree, get it to a known mechanic indeed.good luckDave M
Here's my take:If you do twelve things at once you'll never know where the improvement came from.Get/check a tune up, that'll set your baseline: valves and injectors settingsBe sure and short the injectors while your there, listen for gross difference...no difference then you found a weak cyl.< (injector, valve or rings/piston or all of the above)Go drive it.Set the governor up another 2-250 rpm no load.Drive it.Still not happy twist the gov to 2325 max.If there is no remarkable/noticeable improvement Re-gear itHaving said that I wouldn't even touch the motor until you've told us what the final gear ratio is.If it's as low as I think it is your wasting your time until you re-gear.Then after you know the gearing, start thinking about the turbo.AND BEFORE ALL THAT...well consider that a 1983 model motor just might need rebuilt, My 1978 is no virgin and as much as it sounds like that motor has spent against the governor I'm willing to bet it needs some TLC.I have never seem a DD motor that did not have at least the oversize rod bearings stamped some where on a heavy metal coupon that would stick out like a sore thumb.(Every rebuild I have done or saw has it)If it ain't there That motor has to be tired there is no way that it can't be.what are the gear ratio.
In the meantime... maybe this will help...Around 1900-2000 @ 60. Almost can hit 70 on a flat given cool air, 10 minutes tryin', and an RPM of about 2100ish.?
That sounds like 4.1 axles. I get 67 MPH at 2100 RPM with a 4.1 and 12R22.5 tires. At least your transmission ratios are slightly closer than a regular MT transmission's.Get that lead outa there. You need to put your bruck on a diet.John
To get really crazy, you could pull the lay down 6-71TA and install two 4-71's end to end with a HT740 (shorter then your transmission). Then you could safely have 400hp and 1200lb/ft torque.Some will say that doesn't work as exampled by the first drive train in the PD4501's. But you have to remember, the Scenicruiser was running the two engines side by side with a hydraulic coupler. You'd be running the engines end to end drive shaft attached as one engine.Detroit during WWII made a quad 6-71 marine engine. It was rated at 900hp max and 650hp continuous. What was unique was that you could throw the clutch, turn off one engine while the other three were still running. Good Luck, TomC
