Author Topic: 1985 MCI 102A3 - Fuse Box??  (Read 2462 times)
Offline AngelsFastpitch
    • Angels Fastpitch
« on: June 17, 2014, 05:58:56 AM »
I blew a fuse this past weekend and now none of the speakers/tvs work.  Does anyone know where the fuse box is and what i'm looking to replace?  Maybe someone could point me to where I can purchase a owners manual or spec doc for a 1985 MCI 102A3 Bus
thanks
Let's Roll
Offline Dreamscape
  • Dreamscape
  • Global Moderator
    • Dreamscape Eagle Travels
Re: 1985 MCI 102A3 - Fuse Box??
« Reply #1 on: June 17, 2014, 12:59:26 PM »
This was in Bus Projects. Thought it would get more exposure here.
Anybody?
Offline Dave5Cs
« Reply #2 on: June 17, 2014, 08:21:18 PM »
You might want to at least put a first name and what area you might be close to incase another Busnut is close by that could help you out if needed.
As far as where is the fuse box is like asking what color should I paint my coach. We don't know what system all these things are a part of. Is it part of the original from factory part or a professional converter or a home built coach. My fuse box, actually breakers, for those things would be right above my head when I am driving. There is an AC panel for all the 120 volt house equipment and a DC panel for all the 24 & 12 volt stuff.
So sounds like a 12 volt circuit. If you can't find it either trace it from the battery's or or see where it is plugged in at and see if there is a fuse somewhere on that line. You might try using a good toner to trace the wiring down to the fuse or popped breaker.
E bay has manuals sometimes and just do a search for your coach. You can get reprints on some sites. Someone will probably put a link up. I can't find the link.
There might be a main fuse for all circuits also. Sorry best I can do with little info.
Dave5Cs
« Last Edit: June 17, 2014, 08:27:00 PM by Dave5Cs »
"PATHFINDER" (PFBus)
 1998 Jeep TJ (PFTOED)
Offline bevans6
  • 1980 MCI MC-5C
« Reply #3 on: June 18, 2014, 06:56:39 AM »
It seems your bus is a seated coach used to transport your softball team.  The TV's might be an up-fitted install, or they might be stock.  The MCI doesn't have fuses stock, it mostly has auto-reset breakers.  They will be in one of the three electrical bays - under the driver's window, in the AC bay, or in the engine compartment.  If the system is a retrofitted install, they could be anywhere.
Offline Tikvah
    • Dave & Amy
« Reply #4 on: June 18, 2014, 10:42:46 AM »
I have the same bus.  It seems amazing, but you won't find any fuses.  Check under the driver side window, accessed from the outside.  There will be a wire diagram on the access door.  Your wires will terminate there....guarnteeed.
1989 MCI-102 A3
DD 6V92 Turbo, Alison
Tons of stuff to learn!
http://dave-amy.com/
